General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Installing radio.Which is power wire??90 toyo
Old May 26, 2009 | 11:20 PM
chrisspliff's Avatar
Hey everyone.
I have a 90 toyota pickup 3vze and need help locating the power wire to install a new radio. I installed my last radio (died) a while ago and the only power wire i could find was the horn. For some reason that was the only wire giving power to the head unit. What color is the power wire for radio installs? Red is my guess but no power there. Any1 Know what color i should be looking for? thanks
Chris
Old May 27, 2009 | 02:05 PM
Update: I cannot find the ground or power wires. According to the wiring diagram the ground is brown and power is blue/yellow.How do i locate these wires. The wires that i am working with is connected to the cig lighter. Is this where the wires are located??There is no other wires nearby.
Old May 27, 2009 | 02:37 PM
bxlt's Avatar
Get a test light and start poking wires. As long as your truck doesn't have an airbag and it doesn't you can safely use a test light, and they are cheap!
Old Feb 17, 2011 | 08:47 PM
vw2toy's Avatar
www.the12volt.com has wiring tables that will convert original color codes to color codes used by modern radios
Old Feb 17, 2011 | 09:02 PM
justin_4runner's Avatar
has someone cut out the oem wire led to the radio??? should be a plug in and play set up. shouldnt have to be cutting and splicing the radio in.
Old Feb 19, 2011 | 12:04 PM
91blackpearl's Avatar
After you Find the wires, Go on ebay and look for an eclipse wiring harness, the Harness is exactly the same as a factory harness then you can use plug and play kits.
Old Feb 19, 2011 | 12:46 PM
wyoming9's Avatar
Red face
Yes indeed you gotta love people who cut off the factory plug then can`t figure out it is so easy to just buy the adapter to plug into the new unit.
Until you get to the point that your pushing so much power and your vehicle is now just a mobile sound system the factory harness works just fine.
There should be a plug but who knows it could be long gone.
If you can`t find the correct wires as you need one always powered for the presets or you will lose them every you shut it off.
Old Mar 20, 2011 | 06:36 PM
chuntr's Avatar
get a test light or a voltmeter. you should have one wire that has power at all times and one that has power only when the ignition is on. on a modern stereo usually the yellow wire is constant power and the red is ignition power and should have a fuse on it.
MO transplant
Apr 23, 2023 11:58 AM
BushPig
Oct 29, 2022 06:26 AM
icentropy
Sep 16, 2020 02:47 PM
nick b
Jul 11, 2015 04:38 AM
bryan34w
Jul 6, 2015 05:53 PM
