Body Lift shifter problem? Here is the fix.
Old May 18, 2009 | 04:23 PM
Tragic Drive's Avatar
This is for 88~95 trucks and 4Runners with the V6 + R150f Manual Trans.
So I installed a 2” body lift on my 4Runner a few years ago. I noticed the shifter didn’t sit as high in the cab. The shift boot was also rubbing on the plastic interior trim. This caused the shifter boot to get a wear hole in it. And shifting into gear was a pain in the ass. So I trimmed some sheet metal and moved the black rubber shifter boot/seal back a little. This fix helped some but it still wasn’t that great.
Anyways I knew that some short shifter kits raised the shifters leverage point and the shifters sat higher. I found some on URD but they were listed for the newer 96 and up trucks and 4Runners with the 5vze. Guess what! It fits our R150f equipped trucks as well. I dont know what Tranny the 96+ trucks use but I suspect it is the same. I’ve been using it for about three years now and it works great.
Caveat, I recall one person on another forum that installed this on his 88 truck and said the shifter itself was bigger at the pivot point, he got a newer shifter from the boneyard and it worked.
Good luck with your projects
Check your transmission here http://www.4x4wire.com/toyota/faq/parts/
Before: You can see how low the shifter sat.
After: You can see how much higher it sits and the wear mark from before.
Here is what the kit looks like:
http://www.urdusa.com/product_info.p..._id=1230100042
Old May 18, 2009 | 07:33 PM
Tubbyfatty's Avatar
haha, i was reading about this somewhere else on here. I think you posted it
Old May 18, 2009 | 08:46 PM
UKMyers's Avatar
I have a 2" BL also and did the extension that came with the kit and I"ve always hated my throw. It seems like it's 3 ft from first to second gear sometimes. So if I get a shifter out a 96+ and install a URD short shifter kit it should all fit? I had one of their kits in my 6 speed Taco and loved it.
Old May 18, 2009 | 08:51 PM
yoterr's Avatar
hermmmm, looks an awful lot like the trandfer case short throw another guy makes, cant remember the friggin web site right now tho....
Old May 18, 2009 | 10:04 PM
space-junk's Avatar
www.4crawler.com ??
Old May 19, 2009 | 01:40 PM
You might not need the 96+ shifter, the one you have might work just fine.
Yoterr, 4Crawler makes a short throw transfer case shifter that looks like URD's. I don't believe he makes one for the R150f transmission though.
Tubbyfatty, I posted about this fix 3 years ago and forgot I had posted it. But the info is still relevant.
Thomas,
Old May 19, 2009 | 03:54 PM
anthony1's Avatar
I wonder if it will work with R154 that came in Supra.
Old May 19, 2009 | 04:14 PM
Jay351's Avatar
Thomas,
So how much did it raise the shifter? I have a 3" bl and ive already welded in the extensions into the shifters. It has super long throws, and I hate it. So I was thinking, I could just go get a stock shifter from a tacoma, and buy this.
but I want the shifter to be the right height...
Old May 19, 2009 | 05:19 PM
On my 95 Runner 2" body lift it raised the shifter maybe 1" to 1.5" . It feels comfortable to me at this height kinda right around stock height. Plus its got less than stock throw ratio (short shifter) this was a big plus on my fast rev motor.
The welded on or bolted on extensions are like rowing a boat when you shift compared to this upgrade.
Jay, since I don't have the 3" body lift on my Runner I don't really want to advise you on how it will feel. I'm sure it will help but I don't know.
Old May 19, 2009 | 05:24 PM
Jay351's Avatar
Well, I could always get a screw on 1.5" extension or something. Long throws, oh yeah! I hit my sterio everytime I go into 5th
Got any before/after pictures of the throw distance?
Old Jun 10, 2009 | 02:56 PM
No before and after pics but my knuckles are no where near the stereo when I shift.
Old Jun 10, 2009 | 03:03 PM
CRafferty's Avatar
Originally Posted by space-junk
^^x2 On his site he actually posts a link from the page with the body lifts to the page where he advertises his shifter extension.
Old Jun 10, 2009 | 03:54 PM
Tubbyfatty's Avatar
I wish this wasnt $150, ugh. lol.
Old Jun 10, 2009 | 04:03 PM
Where is the link to 4Crawlers short shifter for the transmission not the transfer case ?
I know he makes one for the transfer case http://www.4crawler.com/4x4/ForSale/...wShifter.shtml. However for my 2" body lift the transfer case shifter wasn't needed.
I think he even makes a shifter extension for the transmission but it doesn't raise the shift fulcrum it just extends the shifter itself.
Old Jun 10, 2009 | 06:01 PM
Tubbyfatty's Avatar
I dont think 4crawler makes a short throw for the tranny. Just the t case. I wish he did tho cause im sure it would be cheaper then 150 haha.
Old Jun 10, 2009 | 06:11 PM
gary96360's Avatar
i didnt bother to extend my shifter when i did the 3 inch body. i just bent the shifter forward
Old Jun 19, 2009 | 09:55 AM
Stuwy123's Avatar
Any problems with shifting or hitting the dash if you don't put in the shifter extension for the 3" body lift?
How did you bend it?
Jun 1, 2021 01:51 PM
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
