2001 Taco; 3.5" front suspension lift, what to do about the rear, (NO AAL's)!?
Hi guys. Well for the time being it looks like I might be in my 2001 Taco instead of a 4 runner, so my suspension plans have changed a little bit. I am still planing on running the OME's up front for about 3-3.5" of lift instead of the coil spacers that are currently on there, and I also want to ditch the add a leaf that is on there because I want the best ride possible, and I just want to get some opinions on what I can do for the rear, because I can't find any info on the OME Dakar leaf packs on how much lift they provide, but essentially I want the best riding setup that will do well offroad, and I want the truck to be level and have just enough lift to fit 315/75/16s. Anyways thanks alot for the help guys.
Im planning on all pro 3" rears to match my ome 881's up front..
If you go that way, after they settle I heard they were about 2.5", Then you could just get some shackles...
BTW, Check out TTORA, there's soooo much info over there about lifts and things..
Better yet, Check out This for some good tech..
I believe wheelersoffroad has numbers for the ome dakars, heard they sag over time too..
Good luck !!
Good luck !!
Better yet, Check out this thread for rear sprrings
http://ttora.com/forum/showthread.ph...af+spring+poll
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
Jul 9, 2015 02:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
