Removal of Air Injection System? 79 2wd 20r
I recently bought a white 1979 2wd short bed toyota.
It has the 20R with the air injection pump stuff.
I was wonder if someone could point me int he right direction for removing the system. We don't have smog testing in NC.
If I take everything off that has to do with the AIS will the truck run?
I took all that off mine as well. Then i build a 20/22r hybrid and got rid of all the smog/AC and vacc lines from my 20r carb that i am using on it. I now only have 3 vaccum lines coming off my carb and it runs great.
then what are the only vac lines i need to run for the 79 20r carb to run fine? i just want to take everything off and put the most basic setup on with out going to a weber. i have no idea what half these sensors and such are for on and around the manifold. I have never really dealt with a carb. mostly EFI on Volvo's and a 87 chevy 350
its hard to say what the 20r carb needs and doestn need to run good I have capped off the many ports on the stock carb before and it ran ok but it was a hurting carb to begin with now I have a weber.
What I can tell you it you can delete the entire EGR system, buy or make block off plates. you can block off the manifold at the exhaust, head, & intake.
The Weber is the only way I know how to simplfy the vaccum mess its really not that expensive for the conversion kit.
Good milage and performance increases too
nanhodges2733
May 29, 2020 03:28 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
skoti89
Jul 8, 2015 12:05 AM
