Questions about block heater replacement (with pics)
So, my 3vze was leaking again. After getting underthere I noticed a little drip under the block heater. I took the oil filter off and just tried to take the plug boot off, but...woosh! All the coolant came rushing out. That thing was ready to just fall out.
Questions:
Where do I get a new one?
Any tips?
I had a rag over the oil filter intake area, do I need to do anything special if some coolant got into the engine? I don't think more than a shot glass could have gotten in, but I could be wrong.
Pics:
Questions:
Any tips?
Pics:
You don't say where you are but lots of places will have them.
Napa will, dealer will and autozone can order them etc.
Or, you could check the one you have out and put it back in.
Or, if you don't need it, put a plug in.
is this it? i'm thinking about this for cold indiana mornings. do you run yours on a timer? any idea on consumption?
alfio
alfio
When I replaced my motor I did NOT replace the block heater. They are a pain (leaks) and fairly big power users. I did put a 75 watt silicone pan heater on. The advantage of the block heater is you get warm air quicker. The pan heater heats the oil and you get oil pressure quicker. I figured oil pressure is a little more important than warm air a little quicker. Plus on a really cold moring (-40F) at a very remote lake where the ice fishing is not bad,
I can preheat the truck with my 550watt generator.
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
