she starts shaking...:(
87 toyota pickup.. stock.. no power steering
front tires have a fast leek. its gets hard to turn. when i fill them and when i reach around 30-40- miles per hour, gets easier to turn(duh) but truck starts shaking. when i look at the drivers side tire, its wobbling. the truck stops wobbling if im driving on a road with a slight curve(when the steering wheel is tight).
what do you guys thinks it is-
-steering is jacked?
-somethings loose in the suspension?
its gets really sketchy sometimes... please help
try your tirod ends inner and outter see if they got play...if so its time for then to be changed and if you do change them get a front end alignment. fast air leak front tires? thats def not helping get that fixed or new tires.... oh and if its simple....you tighten all the lugs down? and you most toublesome thing sould be a warped or bent rim.... although i had a 95 4runner with a bad UV joint that did the samething and i turned the wheel and it stopped shaking... but its rpolly not the same..
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
