she starts shaking...:(
Old Apr 7, 2009 | 08:25 PM
87TwentyTwoR's Avatar
87 toyota pickup.. stock.. no power steering
front tires have a fast leek. its gets hard to turn. when i fill them and when i reach around 30-40- miles per hour, gets easier to turn(duh) but truck starts shaking. when i look at the drivers side tire, its wobbling. the truck stops wobbling if im driving on a road with a slight curve(when the steering wheel is tight).
what do you guys thinks it is-
-steering is jacked?
-somethings loose in the suspension?
its gets really sketchy sometimes... please help
Old Apr 7, 2009 | 08:32 PM
Kiroshu's Avatar
try your tirod ends inner and outter see if they got play...if so its time for then to be changed and if you do change them get a front end alignment. fast air leak front tires? thats def not helping get that fixed or new tires.... oh and if its simple....you tighten all the lugs down? and you most toublesome thing sould be a warped or bent rim.... although i had a 95 4runner with a bad UV joint that did the samething and i turned the wheel and it stopped shaking... but its rpolly not the same..
Old Apr 8, 2009 | 07:56 PM
i checked rods and now that u mentioned it,my boots are worn and torn. how much you think it would cost to get it done at a shop?
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
