Why won't my truck start?
Old Mar 28, 2009 | 03:45 PM
dz187's Avatar
Question Why won't my truck start?
Started happening about a week ago on my carbed 86. I went to start it and all I got was a "click." Its not the clutch switch because if I try to start the truck without the pedal depressed I don't even get a click. Tested my battery, that was good. Tried jumping it anyway off my mustang's optima, still clicked. Got out my multimeter and tested my cables... everything looks ok, I get 12v on the control cable to the starter when I try to start it. After doing some research I read that it was probably the contacts in the solenoid. I replaced the contact that looked worn, went to start the truck and got the click again. So I pulled the starter off, hooked a battery directly up to it and it would click, move the plunger, but then it wouldn't spin. The brushes looked good and at this point I just bought a rebuilt Denso starter off the internet. It came in today and I bolted it up, then started the truck... CLICK.
Whats going on??
Old Mar 28, 2009 | 04:28 PM
wheatus's Avatar
are all your underhood fuses intact. i had similar starter issues and it blew the 40 amp AM2 fuse. check the starter relay as well that is where mine clicked at.
Old Mar 28, 2009 | 06:11 PM
dz187's Avatar
Fuses look OK when i checked a week ago. I'll have someone listen to the relay too. Aren't relays supposed to click though??
Old Mar 28, 2009 | 07:48 PM
DIRTYBOYZRACIN's Avatar
Mine did the same thing it was a problem in the small signal wire going to the starter check that out
Old Mar 28, 2009 | 08:18 PM
dz187's Avatar
Well if the signal wire was having a problem would the starter even click when I turn the key?
Old Mar 28, 2009 | 10:14 PM
desertcamper67's Avatar
If your battery tests good and the new starter just clicks, I would take your battery terminals off, clean them, make sure you can't pull them off the cables and reinstall them. This has worked for me and friends several times.
Good luck.
Old Mar 28, 2009 | 10:22 PM
stagger_lee's Avatar
Check ground at battery and where it is grounded. Make sure everything is clean. If you have power/amps and starter is good, thats most likely the problem.
Old Mar 28, 2009 | 11:07 PM
Dz the starter will still click if that wire is bad its just not letting it get enough power i ended up completely bypassing mine and ran another wire from the relay to the starter its been doin fine like that for about a year now
Crazychris1871
Jun 27, 2016 10:38 AM
Cesarl74
Apr 23, 2016 06:07 PM
Badger62811
Jun 26, 2015 09:26 PM
newzingo
Jun 24, 2015 01:50 PM
slider417
Jun 22, 2015 10:18 AM
