Mystery Sound Persists
My mystery sound persists. I have a stethescope now, and spent the better part of an hour listening to different parts of the engine to no avail. I can not for the life of me figure out where it is comming from. I think the sound is the same on the uptake of the engine rev and when under load. It sounds like a lower frequency than what I would immagine piston slap to be. I listened to all different parts of the exhaust manifold and intake manifold. All over the valve cover timing cover, head and block where I could get at it, and no matter where I had the stethescope it sounded far away. I changed the spark plugs tonight to make certain that I wasnt getting poor spark in a cylinder. I set the timing to 8deg before TDC, I tried moving the distributor 1 tooth, but I couldnt get within range of the distributor slide to get it down to 5deg. Please anyone thoughts? Here is the link to the video again. http://www.youtube.com/results?searc...oomster81&aq=f . If a video of something in particular or pictures of something would help please let me know. Thanks.
I had the stethescope all over the egr valve last night. I will drop the down pipe tonight and look at those doughnut gaskets, to make certain there is nothing too screwy with them. Thank you all for your advice. PS I played with the timing for a while last night. I have it set to 8deg now, but that is maxed out in the slider range for the distributor. I tried changing the tooth, but then it is maxed out the other way. I have the jumper in, and it's flashing the engine light. I'll let you know the results of changing the doughnut gaskets. Also I just changed the gasket from the injection tube connecting to the crossover pipe from the manafold to try to get rid of the sound to no avail. I think I will pick up the gaskets between the injector tube and manifold tonight to see if that does anything for me. Thank you all.
So tonight I changed out the dougnut gaskets between the manifold and down pipe. While I was down there I noticed that the o2 sensor was sitting on top of the exhaust pipe. Not good. Luckily it hadnt been sitting there too long so no exposed wires. I still wanted to be certain though so I cut all the wires and spliced back in new ones. The sound did persist, now I may be hearing things but it did seem lessened, but still obviously there.
Bourbonblues
Dec 15, 2017 05:43 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
jacked_72
Sep 14, 2015 03:31 PM
