Body lift question
CALLING ROGER BROWN
http://4crawler.cruiserpages.com/4x4...yLiftKit.shtml
Not only will you save $$$ you will get a much more QUALITY product. Look into his lift and his site. Its LOADED with info.
I SECOND THAT
Originally posted by PoBoy
CALLING ROGER BROWN
CALLING ROGER BROWN
Brian
If you would have read the link, you could have seen that his kits do not require welding, understood that most bodylifts are about the same and found the answer to the question.
Truck specs, or at least year help a lot in answering things of this sort.
Rule of thumb on 2nd Gen runners.
1", what I have, no real mods. Remove fan shroud, leave all other linkages, redrill front bumper mounts.
2", shift linkages need to be addressed, possible relocation of radiator or fan.
3", tranny and transmission linkages need to be addressed, levers for 5 spd may need to have extensions welded on
1.im trying to find out something about the performance accesorys lift.
2. does the roger brown 3 inch body lift come with steering linkage because i have heard that it doesnt and that is why i want the performance accesorys lift.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
