propane and bending
Old Mar 2, 2009 | 08:10 PM
ericyota's Avatar
propane and bending
hey everyone, got a newb question: is there a tip made that can be used on a bernz-o-matic style propane bottle to produce enough heat to bend steel tube?
Old Mar 2, 2009 | 08:24 PM
tc's Avatar
tc
Nope - propane gets no where near hot enough. MAPP might get close for small stuff, but you really need oxy-acetylene
Old Mar 2, 2009 | 08:31 PM
4Crawler's Avatar
Probably need to add some oxygen to the propane to get enough heat to do that:
- http://www.sculpture.net/community/a...hp/t-3372.html
Or get a tube bender and do it cold.
Old Mar 2, 2009 | 11:31 PM
ericyota's Avatar
id love a tube bender, but they are out of my price range at this time. i have also noticed oxygen cylinders at home depot next to mapp and propane. any idea if the pure oxygen would provide enough heat? thanks for the link too, it gave me some good insight, i never considered the used regulator danger.
Old Mar 3, 2009 | 01:22 AM
91 4Runner's Avatar
NO you'll need to buy the Mapp/oxygen torch kit to run the two gasses - it will get 1/4" plate red hot, but the oxygen will run out fast....
Old Mar 3, 2009 | 07:53 AM
dirtoyboy's Avatar
What are ya trying to do exactly?
Old Mar 3, 2009 | 08:13 AM
4Crawler's Avatar
Tried one of those Mapp+O2 small cylinder kits. You can get steel hot enough to braze and weld but like mentioned above, you run out of O2 really, really, really fast. Like in my case I was trying to weld a washer to the top of a nut and I could just barely get that hot enough to get a little welding done before I ran out of O2 (like a minute or so as I recall). And that was with a small little pencil point flame for welding. I could imagine with a larger flame to heat a larger area, you might blow through one of those small tanks in seconds.
Old Mar 4, 2009 | 01:13 AM
91 4Runner's Avatar
If you keep the flame just lower than hissing (cutting type plame) you can stretch out the O2 for 5-10 min. Any longer than that and you're pushing it.
nvdesertrunner
May 11, 2020 08:18 PM
wafoogalla
Nov 2, 2016 11:02 AM
jb451
3.4 Swaps
Aug 31, 2015 06:23 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
nick b
Jul 11, 2015 04:38 AM
