10.5" Tundra axle vs Full Float 8"?
What would be stronger?
A rear Tundra axle with the 10.5" diff like this
http://www.4wheeloffroad.com/techart...xle/index.html
or a regular 8" differential axle with this kit on it
http://frontrangeoffroadfab.com/nfos...06e62fd0182578
The only thing is there don't seem to be any lockers for the 10.5". Maybe a T100 axle (the so called "8.25") with the full float kit is the way to go?
http://home.4x4wire.com/erik/diffs/
The 10.5" Tundra axle is going to be the strongest obviously. Read the article you posted, that thing is huge. While its not a full floater, look at how they beefed up the portion of the axle supporting the weight of the truck:
What could you possibly need more axle strength for, the Toyota 8" is very stout already?
Ah, just curious. I don't think I'll ever be grenading a full float 8", but if I happen to come across a cheap Tundra axle...Do they have discs in the back?
EDIT: No it's a drum.
I bet they're way different widths though.
I guess it depends on how you look at it ... Tundra axle will be a helluva lot harder to grenade, but when it does, your wheel comes off.
8" FF will break easier than the Tundra, but you just remove the broken part and drive on ...
Wouldn't the tires loose traction way before that (unless they were wedged). Any idea what the tires can take in terms of torque before the lugs tear off, the side wall tears or separated from the bead.
Yes, there is no way the tire can generate that much friction - wedged is the issue. I can tell you on the front that the Warn manual hub, the lugs, the R&P, and the diff stub shaft have all survived when a CV shaft hasn't ... my hub dowels ARE in pretty sorry shape though!
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Suprarossa
Jul 6, 2015 05:21 AM
