Real world BJ spacer flex
Old Feb 22, 2009 | 10:12 PM
Matt16's Avatar
Went out exploring today. With BJ spacers, torsion bars relaxed to stock height, the swaybar disconnected and the tires at 20psi, I noticed that the truck pitched less from side to side going over boulders. In this vid, you can actually see the front flexing a bit.
In all, I am happy with the BJ spacers, and other "IFS flex mods". Aside from maybe adding low profile bumpstops, I think my mods to the IFS are complete. Note, my IFS steering still needs to be beefed up with an idler arm truss. Instead of lifting the passenger tire, the tire stayed on the ground and allowed the drivers side to grab the boulder.
Maybe not all that impressive as its only flexing maybe 4-5", but if you only got 3" to start with, 5" is huge... (PS-you'd better not quote me on that last bit in your sig line.)
[YOUTUBE]http://www.youtube.com/watch?v=xi28TLAtrCE[/YOUTUBE]
Some more vids from today. We were exploring up a creek at Stave Lake. Ignore the recovery strap pigtail I have:
Watch the passenger side suspension working, it really is flexing!
[YOUTUBE]http://www.youtube.com/watch?v=2LRpUbPzp_s&feature=channel[/YOUTUBE]
[YOUTUBE]http://www.youtube.com/watch?v=fOmgqoB1HYs&feature=channel_page[/YOUTUBE]
Old Feb 22, 2009 | 10:19 PM
toyota4x4907's Avatar
Very nice
(( I like your truck))
It does have some pretty good "flex"!!
Old Feb 22, 2009 | 10:29 PM
algranger's Avatar
hardcore!!
jk thats pretty cool that you got the flex out of almost stock ifs.
Old Feb 22, 2009 | 10:45 PM
Plumbrbob's Avatar
right on
Old Feb 22, 2009 | 11:54 PM
space-junk's Avatar
Old Feb 22, 2009 | 11:58 PM
kinzer's Avatar
im really sorry but i gotta!
Old Feb 23, 2009 | 12:08 AM
Matt16's Avatar
Originally Posted by space-junk
You dicks... you're just jealous
Old Mar 4, 2009 | 03:30 PM
the 38 special's Avatar
Does it ride similar, better, worse on road? freeway.. Highspeed (under normal driving conditions) cornering.. etc..?
I am considering BJ Spacers, turned down torsions to stock height, swaybar disconnects, and air shocks to take more load off the TB's .. that will help transfer weight between the left and right wheel to maintain traction and increase flex.. I hope..
Old Mar 4, 2009 | 03:33 PM
874runnersr5's Avatar
nice setup man
Old Mar 4, 2009 | 03:34 PM
iamsuperbleeder's Avatar
very nice!
bet it leans like a some-bitch around corners with the sway-bar dico'ed and the t-bars relaxed geez mine's got a lotta body roll after removing the sway bar with torqued bars! but my shocks are shot too
Old Mar 4, 2009 | 04:30 PM
Matt16's Avatar
Originally Posted by iamsuperbleeder
very nice!
It leans a bit more when disconnected, but it takes me less than a minute to reconnect the sway bars, so I re-attech the bars after airing up (no time during airing up cause it only takes 20 sec/ tire with York OBA
https://www.yotatech.com/forums/f129...onnects-75746/
Old Mar 4, 2009 | 04:58 PM
arizonaguy's Avatar
spacers
great, fabulous, outstanding, glad for you, bravo, bravo!
Old Mar 4, 2009 | 05:45 PM
oh right on I just completely removed mine just dead weight to me... although I may re-install it; I dunno... we'll see if it changes this weekend with the new shocks, bj's, TREs, idler, and pitman arm, new rubber, and a fresh alignment oh yes, I have a busy, and expensive weekend ahead of me...
Old Mar 4, 2009 | 06:01 PM
Matt16's Avatar
I've needed to make emergency avoidance maneuvers on the the highway, I wouldn't want to do that without my swaybar. Its not during the regular driving that the sway bar is critical- it isn't unless you take corners stupidly fast, its the emergencies.
Pickup lacks to 500 extra weight above the COG.
The disconnects are so easy to make, why risk it? Rollovers suck.
Old Mar 4, 2009 | 06:09 PM
Junkers88's Avatar
Matt I checked out the link to your disconnect thread and really like the way that turned out. I'll have to see if that can be done on a first gen runner as well.
Old Mar 4, 2009 | 06:28 PM
wow, thoese are sick disconnects..
im gonna make some!
Old Mar 4, 2009 | 06:59 PM
Matt16's Avatar
YOu could ditch the rod end/ heim joint for first gen 4Runners (I don't know what trucks use to connect the SB to the LCA). That would reduce the cost to around $10- so probably the best improvement/$ there is because the denominator ($ amount) is so small.
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
crash813
Sep 27, 2015 07:15 AM
