Where does this hose go?!?
Old Feb 7, 2009 | 09:09 PM
rotccapt's Avatar
I am putting my engine back into my 86 Toyota pickup with the 22RE engine, and have connected all of the hoses/lines and I am left with one coolant line and i have no idea where it goes, i don't see any unplugged holes. If anyone knows I would really appreciate some help. Here are some pics.
THANK YOU!
Attached Thumbnails Where does this hose go?!?-p1010487.jpg   Where does this hose go?!?-p1010488.jpg   Where does this hose go?!?-p1010491.jpg
Old Feb 7, 2009 | 09:19 PM
fdeeznutz's Avatar
That's a fuel line. It connects to the fuel pressure regulator on the fuel rail.
Old Feb 7, 2009 | 09:27 PM
toyota4x4907's Avatar
It snakes up to the rear of the intake plenum area near the firewall.
Old Feb 7, 2009 | 09:40 PM
iamsuperbleeder's Avatar
correction...
It's the inlet fuel line leading to the fuel filter. It loops up then back down to the fuel filter, and it would appear from your 3rd picture that you have the outlet from the filter hooked to the fuel rail already
it's hard to see in this nasteyness, but you can see the same hose on the bottom-left of this picture from when I removed my intake:
Old Feb 7, 2009 | 09:45 PM
2 more, just for clarification...
Old Feb 8, 2009 | 05:21 AM
rotccapt's Avatar
i am almost positive it is not fuel all my fuel lines have that special connector on them that has the bolt on it. this line went on a barb connector and i think it had coolant come out of it when it was disconnected.
Old Feb 8, 2009 | 05:30 AM
Shawn6string's Avatar
Originally Posted by iamsuperbleeder
correction...
Two words " steam cleaner "
Old Feb 8, 2009 | 06:00 AM
you do have 2 coolant lines on that side, that go to the throttle body, or more specificaly the IACV, but those do not go near the fire wall. the only coolant lines that go near the firewall are the ones to the heater core, and those are on the complete other side of the motor. the fuel line is in 2 separate peices over there. there's the one you've pointed out that runs from there at the firewall to the fuel filter bolted direcectly to the motor block under the intake, and then out of the other side of the filter there's a line that tuns up through the gap in the intake manifold and goes to the fuel rail
just turn the igntion and see if fuel sprays out...
yeah yeah, I know
Old Feb 8, 2009 | 06:17 AM
rotccapt's Avatar
thank you all it was a fuel line sorry for the mix up. thanks for your help. after a closer look at my spare intake and the line i saw that it said fuel on it and i found where it went on the intake hope to have it running today. it connects to the fuel rail not the fuel filter
Old Feb 8, 2009 | 06:34 AM
sigh...
yes, it is a fuel line, but that line DOES NO CONNECT TO THE FUEL RAIL, it goes to the fuel filter; I am 230% sure of it
Old Feb 8, 2009 | 06:35 AM
rotccapt's Avatar
this is the missing line
Old Feb 8, 2009 | 06:37 AM
you've just lost me...
now you've pointed out 2 different hoses...
Old Feb 8, 2009 | 06:41 AM
rotccapt's Avatar
sorry here is a better pic
Old Feb 8, 2009 | 06:54 AM
oh... ummm, ok...
well this first line you pointed out:
definately does not go here:
that's what it appeared like you were saying
Old Feb 8, 2009 | 07:08 AM
rotccapt's Avatar
sorry for the mix up in my first pic it was a bad angle and you can not tell that the line that my wife was holding does not have a connector on it. i already connected both fuel lines one from the tank to the filter and the filter to the fuel regulator. thank you for the help and the pics they helped out a lot. also i looked at my spare intake and it had the complete line still attached to it so that is how i figured it out.
fdeeznutz's Avatar
The line in this picture DOES go to the FPR
Take a closer look, there is no barb fitting on the end of it for the fuel filter. I looked on my truck before I posted my first reply. That line in the picture 100% goes to the FPR.
Old Feb 8, 2009 | 07:15 AM
rotccapt's Avatar
thanks for your reply here is a better pic of the line in question
Old Feb 8, 2009 | 08:05 AM
haha, oh ok, yeah I noticed the ring and was going to comment, but I decided against it
well holy crap dude, your right
I'm not affraid to admit I am wrong; I surely though that was the inlet line, not the return line it's been a while since I've screwed with that side of the motor
that even makes since looking at my pictures and where it loops around to
fdeeznutz
Old Feb 8, 2009 | 09:14 AM
qdude79's Avatar
"Where does this hose go?!?"
If I had a nickel for every time....
Old Feb 8, 2009 | 10:19 AM
rotccapt's Avatar
thanks all i thought i had labeled ever stinking thing but i missed one and some of my numbers disappeared and there you have it one extra line with no home in site. sorry for all the confusion im just happy the line found a home. now to fill it with fluids and put the belts back on and turn the key. thanks again
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
kcaudill
Oct 10, 2015 02:39 PM
taraf
Sep 25, 2015 02:57 PM
