15x7 3.75 BS with 31x10.50r15.... got pics?
I know, I know.. thus thread is ANCIENT but I'm about to order the same setup. Can anyone confirm how much this will stick out on a 91? Or have any pics with a 15x7 with 3.75 BS?? Been searching like crazy and cant seem to get a clear answer. Thanks!
most people running this aftermarket spec wheel are running tires larger than a 31. I'd suggest you simply look at pics of people running 33x12.5 tires and imagine a narrower tire on them. they're all going to stick out further than stock - 1" further out because of the 3.75" backspacing (vs 4.75") and at least another 1/2" out from the 8" (vs 7") width.
why do you want a 15x7 with 3.75" BS?
I currently have 235s on 15x6 in. stock steelies and have a bit of life left in the tires as well. I was thinking of getting the wheels first, then go to 31x10.5s when I need tires.
This will be a daily driver for me for a while. I'm at stock height and figure if I ever spring for a lift, regear, and wider tires, I'll go with wider wheels then.
another thing to consider is looking for a set of stock takeoff wheels from a newer tacoma/4runner - many of them had the equivalent of 31x10.5 stock (on 16" wheel). I'm guessing you can find an inexpensive set of takeoffs, then sell your current tires if they still have meat on them. it's another option to think about.
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
Sep 9, 2015 02:43 PM
