pulling dash apart?
Old Jan 27, 2009 | 07:15 PM
nomiss05's Avatar
pulling dash apart?
i have my dash apart, well most of it. i cant figure out how to get behind the air con to change the light color. i changed my cluster color but it looks horrible with green on the aircon lights, just wondering if anyone knew what to look for or if there are good write ups for it
Old Jan 27, 2009 | 07:25 PM
myyota's Avatar
If your trying to get to the light bulb on the heater control thats a real pain in the butt, the light socket snaps into the back of the heater control, so you can either disconect the hearter control cables and pull the control out, or remove most of the dash to get to it, wich ever you think is easier. its very easy to remove the dash, or atleast i think it is because ive replaced a couple of heater cores so ive done it a couple of times.
Old Jan 27, 2009 | 07:38 PM
20twinz's Avatar
yea its not to bad realy.
Old Jan 27, 2009 | 08:43 PM
herpestes's Avatar
remove the knobs from the heater controls and carefully pry the face plate off. the bulb is located in back. it may make it easier if you remove your ashtray and the bracket to hold the socket from the back when installing replacement.
Old Jan 27, 2009 | 08:58 PM
904_runner's Avatar
Damn, i have to replace my heater core soon, since mine leaks. UGH
Old Jan 28, 2009 | 08:31 AM
nomiss05's Avatar
so i dont have to take it all off? jsut pull the face plate off?
Old Jan 28, 2009 | 10:05 AM
herpestes's Avatar
should not need to
Old Jan 28, 2009 | 12:11 PM
nomiss05's Avatar
also, while i have the face off.. my low does not work on the air con, all the other settings work except low, i did not knwo if this would be in the switch or somewhere farther back. anyone know?
Old Jan 28, 2009 | 12:34 PM
22mr2's Avatar
Mid 80s trucks show a blower resistor listed but Im not sure where it is. The last time that happened to me it was the switch itself but it was also a newer truck(91)
Old Jan 28, 2009 | 12:37 PM
nomiss05's Avatar
i dont know much about air con stuff itsself, but i guess it is awitch since all the other settings work just not low. but i could be wrong
Old Jan 29, 2009 | 12:16 AM
XtraSlow_XtraCab's Avatar
Blower motor resistor is located right behind the blower motor itself... closest to the firewall. Two bolts that should be 1 to 2" beside each other with a rectangular plug in the middle. Removing the bolts exposes the resistor.
Old Jan 29, 2009 | 10:17 AM
nomiss05's Avatar
so should i look at switch or blower resistor?
Old Jan 29, 2009 | 01:13 PM
herpestes's Avatar
would check out the switch first as only the low speed is not working. terminal 4 is the common, 5 is low, 1 is med and 2 is high. shouldhave continnuity from 4 common to 5.
Old Jan 29, 2009 | 11:44 PM
nomiss05's Avatar
so i can jsut pull the switch out and look at it? wont mess it up will i?
Old Feb 1, 2009 | 08:12 AM
yotadude85's Avatar
probly not, if it does its not going to be too expensive at a wrecking yard. id go get another one anyways and try it. i have had the same experiences with only one speed not working and every time it was the resistor but ive never had that problem with any of my toyotas=) just check the switch first just because its easier to deal with, resistors can be hard to find.
Old Feb 1, 2009 | 10:44 PM
I disagree. I believe it may be the resistor, as the 2nd gen trucks (1st gen runners) actually have a seperate resistor coil for each individual terminal. They're very fragile and are bent and broken very easily. Its generally a common problem.
By 1991, someone was smart enough to encase the coils to prevent damage caused just by handling the unit.
Old Feb 1, 2009 | 10:55 PM
herpestes's Avatar
looking at the fsm and the way the power feeds thru the switch and no low but med and high working. looks to be the resistor but since the dash is apart
no harm in ringing out the switch first.
Old Feb 2, 2009 | 07:58 AM
nomiss05's Avatar
i just left it, i have gotten by without a low for a year now, i guess i can keep getting by.
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
Esibnitsud
Jul 30, 2015 08:21 PM
jetspeedz
Jul 13, 2015 09:32 PM
smiley52
Jul 11, 2015 05:16 AM
