What Have they done to my truck
Old Jan 20, 2009 | 02:44 PM
hooligan750's Avatar
Question What Have they done to my truck (Pics Added)
Ok, Iv'e done a few searches but havent found an answer.
Question is How to tell if my Diffs are 7.5 or 8 inch. Is there a way to tell without disassembly. P.O installed a late model wider rear diff from a 4 runner and the front I believe to be stock. I would like to regear and was hoping to order the parts before i take it apart.
Also where is the 7.5 and 8 inch dimension found ( is it to the outside of the ring gear or the bolt pattern on the ring gear)
Thanks in advance
Old Jan 20, 2009 | 02:51 PM
DeathCougar's Avatar
If you have a 4x4, its an 8" diff. You cannot fit a 7.5" ring and pinion in a 4x4 rear diff.
bigt's Avatar
7.5 is froma 2wd truck..
its prolly a 8 inch post a picture and we will tell ya!
i think he means they switch the whole axle out
Old Jan 20, 2009 | 03:13 PM
here are some pics i just shot
Old Jan 20, 2009 | 03:39 PM
That would be an 8" diff
Old Jan 20, 2009 | 04:52 PM
85TurboRunner's Avatar
If it was a 2wd axle wouldn't it have 5 lugs?
Old Jan 20, 2009 | 06:39 PM
Yes, 2wd axles are 5lug, and have a rather small differential. It would be quite noticeable.
Old Jan 21, 2009 | 04:18 AM
sounds good guys
Thanks for the help
Old Jan 21, 2009 | 04:48 AM
Hypoid's Avatar
http://home.4x4wire.com/erik/diffs/
This has a bit on the differentials. Rear axle housing is what the whole assembly (dropout third member) mounts into, and has been a couple different widths, i.e. you can have a "4cyl" diff in the more recent wider axle housing, and I believe they use different half shafts.
http://pirate4x4.com/forum/showthread.php?t=459180
Old Jan 21, 2009 | 02:55 PM
Wow Thanks hypoid that helps alot. Sometimes I forget to broaden my searches outside of yotatech, usually i get all the info i need here.
Old Jan 21, 2009 | 09:25 PM
Hypoid's Avatar
Hey man, glad to help. Feel weird pointing you to a different board, but those measurements aren't on my authority, so I wasn't going to take credit for measuring them.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
thelifeadventure
Jul 2, 2015 03:09 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
