transmission temp gauge sender palcement?
Old Jan 9, 2009 | 08:14 PM
Hayes's Avatar
Where should I install the sender at? I'm too lazy to search right now, sorry. I figure just outside the transmission before the cooler would be best. 22re with an A340H automatic trans.
Old Jan 9, 2009 | 08:24 PM
scuba's Avatar
Wouldnt you want it right after the cooler instead of after, that way you know that the cooler is doing its job...
idk, Now that I think about...would make sense to be right before it also...
Old Jan 9, 2009 | 08:29 PM
Hayes's Avatar
after instead of after, huh?
I would assume you want it before, to see what the operating temp is. Then again, it should be pretty consistent.
Also, I am going to be installing an oil pressure gauge. When I pull the stock sensor, won't that kick the dummy light on, since it will no longer be getting a signal? How can I make it so the dummy light stays off, unless needed and get the reading for my aftermarket gauge?
Old Jan 9, 2009 | 08:30 PM
DIHOWARD's Avatar
just as it comes out of the trans. that way you know the max temp.
Old Jan 9, 2009 | 08:32 PM
Hayes's Avatar
that's what I was thinking.
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
gary4runner
Sep 24, 2015 12:53 AM
Nickyodaman
Jul 27, 2015 12:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
