idler arm rebuild somehow gone wrong. please share words of advice. =\
ok. so in the process of replacing the bushings in my idler arm today i managed (no idea how) to flatten some of the threads over shown here in the picture. My question is wtf do i do now? do i have to buy a whole new idler arm? or maybe somehow cutting new threads or something? any ideas are greatly appreciated. thanks.
here's the pic:
here's the pic:
From: Yotatech, because Pirate is too expensive. NorCal.
That could happen from smashing the end of it with a hammer. Probly did it when you were taking it apart.
You might try re-cutting the threads with a die. Someone with more experience than me needs to comment.
Also to prevent that from happening in the future you can thread a nut onto the studs loosley. Then smack the nut with the hammer to break it loose. That should protect the threads from gettin beat.
It looks pretty bad. I would go to the junkyard and rob one from a junker.
Next time, buy a tierod puller. They are like $25 and make removing these things a peice of cake. I learned by doing the same damn thing with a stuck tierod end..
i believe i am going to try and get the threads recut. if not i will probably get a replacement idler arm from napa seeing as how there are no yota yards around where i live. :/ i was following the idler arm rebuild guide that you made Jay (which was great btw) and didnt realize that i had stripped the damn threads on the idler arm until i had all the bushings replaced, the idler arm back together and on the truck, and was trying to replace the castle nut. :/
does anyone have any experience with this product or similar?
http://www.napaonline.com/MasterPage...Idler+Arm+Assy
it seems like a crazy good price and from the pictures seems to be decent quality.
When I rebuilt mine a year ago,, I just removed the idler arm from the frame, and dissassambled the bushings on the vehicle without removing it from the relay rod. Well to late now. I am going to agree with mt goat on this one.
That's what I do as well. I tried, but could free the idler stud from the relay rod. Ended up cutting it off when I replaced it.
Jcrawl94
10
Oct 24, 2015 04:34 PM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
Jul 21, 2015 07:54 PM
