little help needed if you have a 4x4 truck 90-94
I have no dash indicator light for 4x4 and its not working correctly either. After reading I have found that I have no wire running to the ADD sensor on the front differential. I don't know where it should come from is my problem. Can anyone who has a truck like mine (1992 excab 4x4, V6 5speed) go out and look and tell me where the wire loom comes from, colors, etc. so i can find it on my truck?
Thanks if you can help
found a plug on driver side going down with oil sender wire that is not connected to anything. It is only long enohg to get to the bottom of the alternator and i cant find its home.
Anyone tell mne if this is the wire and somehow someone took of/lost a harness that should connect this to the add sensor. Plug is gray, oval, two wires, green/red and green/white
thanks in advance if you can help
that wire you found sounds exactly like the one that hooks into the wire comin from the front diff. my lite didnt work and that is the same wire i found dangling down past the alt. and near the oil filter...then i had another wire coming from the front diff to connect to it tho...
It sounds correct, although it must be wrapped up there or something. Mine still connects with an additional 4" of suspension lift. The wiring diagram actually shows GRN/WHT and GRN/YEL for a V6, and GRN/WHT, GRN/RED for a 4 Cylinder.
Ok that was the wire for anyone searching this in the future. I first jumped it and put it in 4x4 and the dash light came on. So i then ran a pair wires to the ADD sensor and connected them to the wires in the plug I found. The dash light now works when 4x4 is engaged.
However, i stil have the problem of the hideous knocking when trying to engage the 4x4 in another thread,
Dharris1986
28
Apr 17, 2017 03:34 PM
