upside down
upside down
I have an 89 toyota pickup when i bought it the steering wheel was on upside down.. How do I fix this?? Do I have to be worried about the airbag going off when I do go to fix it??
your 89 should have no air bag theres a few screws holding the horn part on take those out and there should be if i remember a 19mm nut holding the steering wheel to the shaft.... make sure the wheels are good and straight dont take the nut completely off leave a few turns on it now grab the wheel and give it a good yank
Umm....don't know what to tell you on the airbag.....didn't know '89's had them. But, to turn it right side up, if and when you get the front cover off.....there should be screws in the back.....you'll see a nut threaded on to the column. Loosen that and then pull the wheel off the splines with a puller. You can rent them at an auto store. O'Reilly, for example.
Some have had luck just wiggling the wheel off, but I never have.
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
trevor...what?
im pretty sure that your truck has no airbags...
seeing as tho it got the worst rating of an SUV EVER, there wouldnt really be a need for them...
gotta love the 1/2 star rating on the drivers side door and a 3 star on the passengers side...
ok if its upside down is the aliment bad? as in does it turn the same amount of turns to the left as it does for the right? if so then yeah just do the old ol' screw and yank does the trick right guys?
Yep, mine was crooked as ever. Removed the cover, removed the bolt, and hit the edge of the steering wheel with my hand multiple times before it popped off...then aligned it (easier if the wheels are straight!!!)
rimpainter.com
47
Apr 25, 2026 09:13 PM
Corey
Aug 4, 2006 03:26 PM
