Swapping Parts Between Pickup and 4Runner
Hey guys, I've searched the forums and the google and can't really find a solid answer on something I want to try. My 1990 truck has got some rust and dent issues on the front end, and I want to use mixed parts to get the job done.
I like the look of the grille/bumper/valance on the 4Runner ('92-'94) and I want to know if it would be a relatively direct bolt-in to swap these parts on a 1990 pickup. Or similarly, would the grille from a '92-'94 pickup be direct bolt-in as well, or require some modification? I prefer the 4Runner look but I wouldn't mind using the pickup parts if they are easier to install. Has anyone here done this before?
Are interior parts bolt-in? In particular I want the dome light/rear view mirror assembly from a 4Runner. Also, my instrument cluster doesn't have a tachometer and the speedometer bounces up and down when accelerating, what kind of instrument cluster do I need if I have a 1990? I've seen some with a tachometer for sale on the internet but I don't know if they will work with my truck.
For the front grille and vallence from the runner to the pickup, you would have to take the whole core support and cut and weld it in...not bolt in at all.
If your speedo bounces you'll probably need a new housing on the tranny side
You could just put in an aftermarket tach, or do a cluster swap from an SR5
Thanks for the reply. Hmm I didn't realize I'd have to mess with the core and all that, probably better to leave it be. What about a '92-'94 pickup to a '90? Same problem I assume?
Also, I assume I have a mechanical cluster in my '90, so any aftermarket mechanical cluster should work?
1. I do not know, Normally people want the runner grille and all, and thats been discussed plenty of times, so i just know.
2. I dont know of any companys that make aftermarket clusters, I assume you could make your own cluster with aftermarket gauges...
If you're still payin attention to this, I have a 94 runner and I want to do a 90-91 style front bumper conversion so when I lose my lower crappo plastic valance, my turn signal lights dont fall off! I could just get the 90-91 4runner front bumper, but from what I can see, they all come in 3-piece with end caps, and the trucks version comes as 1 solid smooth piece. I was wondering of I could use the bumper mounting brackets and bumper from the pickup and fit that on in place of mine so I don't have to look at those ugly 3-piece thingers. Otherwise, I'll just do it that way. I plan on painting the bumper color-matched green and putting the sonoran steal filler plate in black on with that, and I know it works with the pickup front bumper, its on their shop truck!
From what I have seen lookin at pictures, You said your concerned with taking of your lower valence and the front signals coming off...
Looky here, the 93 + runner pics I have seen look like my bumper/valence..
The Blinker lights actually go into the bumper, not the valence...
If all you want to do is lose the valence, try taking it off real quck...
Im sure you'll be pleased with the look, and your turn signals wont fall off
As for your fitment questions...I dont really have experience trying to swap this and that...But I would guess the bumper from 90-92 would be a direct swap from 93+
Hopefully DeathCoug can chime in...
but that should hold you over until then...
P.S. I think your truck looks yota-fabulous otherwise. I'm just a junkyard upgrade junkie! What tire size are you running? I couldn't find it in your signature or a build thread that you've started per-say.
Don't know about all of em but my 91 pu had a 3 piece rusty bumper when I bought it. If I rember my reseach right both the pu & 4runner were 3 piece till 93. I purchased a new 93 style and installed it. The turn signals fit fine. The metal valance panel did not. Had to finagel that a bit, but with a couple of new holes drilled and some cussin got it on. The relief area at the top side of the bumper where the grill drops is a little different but caused no issue.
Hope that helps a little.
Jim
Jim
Jim
Jim
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
