Torsion Rod Bolt Idea
Old Nov 20, 2008 | 07:00 AM
saitotiktmdog's Avatar
I decided last week to crank up my torsion bars. So in the process I broke the bolts. I figured that would happen. So after ordering new hardware etc I used a bit of anti seize on the bolts and a littel bit of white lithium grease. But in addition to that I sprayed the entired bolt top and bottom after assy with chain lube. It forms a sticky coating on it, that should prevent corrosion. Golden Spectro Chain wax would be another good one to use. Just an idea I had. Dont know if others have tried similar.
Old Nov 20, 2008 | 09:48 AM
drew303's Avatar
you actually broke the bolts? Were the two nuts seized up or what? lol
Thats sketch, them there are some serious bolts and undeniably something that would be catastrophic if one failed on the highway... well i can only imagine what would happen if one side of your suspension gave up.. hmm wonder if it'd be like a flat tire or worse.
Anyway, antiseize usually is enough but I've also never had to deal with corroded bolts. Your in the salt belt tho
Old Nov 20, 2008 | 10:10 AM
Yeah its amazing what you can do with a 4 foot cheater bar on then end of a breaker bar.
Old Nov 20, 2008 | 10:44 AM
dbcx's Avatar
Did you have it jacked up to get some pressure of frontend?
Old Nov 20, 2008 | 11:27 AM
drew303's Avatar
Shouldnt matter
you should be able to turn the bolt by hand with a 1/2" ratchet with minimal effort with the truck sitting on the ground.
Old Nov 20, 2008 | 11:33 AM
I jacked it up initially but once the new hardware was in it was fairly easy to do on the ground.
Old Nov 27, 2008 | 09:38 PM
River_Rat's Avatar
Safety First
Going to be replacing and adjusting my torsion bar bolts tomorrow. I live up in salt country (Canada) so they're obviously rusted and most likely siezed. I was just going to cut them off. Is they're any safety precautions I need to take. I was just going to jack up the front end, cut off the old bolts and replace 'em.
I'm picturing the front end falling apart on my face for some reason, is this the 'safe' way to do it?
Thanks guys. Man I love this place.
Old Nov 27, 2008 | 10:02 PM
91Toyota's Avatar
Okay question...do you have to loosen those two nuts to crank it?
I just got under my truck and turned the nut like 20 times on each side and my truck didn't get any higher. lol
Old Nov 27, 2008 | 11:04 PM
abecedarian's Avatar
some don't have two nuts (not sure if that reflects on the owner....)
Old Nov 28, 2008 | 09:41 AM
91Toyota's Avatar
Mine has two nuts...I just turned the whole thing and nothing happened. Assuming its been cranked to hell already
91Toyota's Avatar
And I've got two...just to let you know
Old Nov 28, 2008 | 02:52 PM
Bigblock's Avatar
You'll have to hold your nuts and turn your bolt.
Bigblock
Old Nov 28, 2008 | 03:43 PM
dlbrunner's Avatar
It is fairly common for those bolts to break.
Word to the wise- before adjusting or when installing new torsion bars. buy new bolts.
Old Nov 28, 2008 | 04:53 PM
91Toyota's Avatar
Bigblock
Can I just hold one?
Old Nov 29, 2008 | 09:24 PM
Skinsfan6's Avatar
91 you tighten those nuts down on the bolt to make your truck higher.
Old Dec 7, 2009 | 01:43 PM
S4amoht4's Avatar
I was gonna replace the upper and lower control arms on my 4runner this weekend. I had the same problem. I couldn't get the torsion bolts to budge. The bolt head and the moonshape looking washer was completely fused together and the nut on the upper side didn't even look like a nut anymore. It looks like a cone...How do you cut them?
Old Dec 7, 2009 | 02:19 PM
mt_goat's Avatar
I keep mine greased up too, makes for easy adjustment and my bolts and nuts are original.
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
RustBucket
Jul 24, 2015 04:46 AM
ShakinIt2x
Jul 21, 2015 06:20 PM
