22re Rebuild Follow along
Old Nov 6, 2008 | 10:11 AM
PDX_1ton's Avatar
Hi all,
I was inspired by All_Terrain17 thread
( https://www.yotatech.com/forums/f116...22-post928655/) as he rebuilt his head. After reading through it I felt I could tackle the job myself. While reading through several other threads I decided it would be best to pull the whole engine and rebuild it. It burns about 2 quarts of oil between changes, besides the now new blown head gasket.
I hope this inspires other they can do the same. For the most part I am following the Chiltons guide. (BTW I have very little experiance beyond changing out a radiator or water pump.)
Before anything is pulled
<hr>
1. Disconnect Neg Batt Cable
2. Remove Engine Undercover
3. Disconnect Windshield Washer host / Remove Hood
4. Pulled the radiator and fan (next time I will snap a few inbetween picts
<hr>
Getting ready to pull hoses. (Labeling everything)
Chiltons says to disconnect the follow
  • No1. and No 2. PCV Hoses (I don't know where those are)
  • Brake Booster Hose
  • Air Contorl Valve Hoses
  • EVAP hose at the canister (Don't know where that is)
  • Vacuum modulator hos at EGR valve
  • Air Valve Hoses at throttle Body and Chamber
  • Two Water by-pass hoses at throttle body
  • AirControl Valve hose at the actuator
  • Pressure regulator hose at the chamber
  • Cold start injector pipe (?? Where is that?)
  • BVSV hose. (What is this?)
I don't know half what the names are for the hoses and wires. The book I have does not have many pictures or diagrams. So I'm just numbering everything.
OK on to Finding the Cold start injector wire adn throttle position sensor. I'll post more pictures and progress as it comes)
Old Nov 6, 2008 | 10:14 AM
PDX_1ton's Avatar
Q: Is the Red arrow pointing to one of the water bypass hoses at the throttle body?
Old Dec 18, 2008 | 10:02 AM
mtcordova's Avatar
What happened?
Is this the end of the thread, did you start a new one?
Old Dec 18, 2008 | 10:07 AM
PDX_1ton's Avatar
Oh I started a new one and am side tracked at fininshing it as I'm about 1/2 day away from getting my engine started after a rebuild.
Look here for something better
https://www.yotatech.com/forums/f116...r-22re-159781/
bigjstang
Jun 2, 2025 03:56 PM
coleypull15
Nov 3, 2015 07:41 AM
jerusry
Oct 19, 2015 05:28 PM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
