questions about fuel pump.
Old Oct 16, 2008 | 10:51 AM
Countryhick's Avatar
Okay. other day i was running low on gas on my way home going down our river road. and ran out of gas. went and got three gallons went back and put it in the tank. Went to start it. and it wouldnt start. it would start sometimes but wouldnt idle. it would just idle a little and stop like its getting no gas.
I was thinking fuel pump.
or maybe even fuel filter clogged.
Any ideaS?
Old Oct 16, 2008 | 10:56 AM
bipolarandproud's Avatar
Spray some starting fluid in the throttle body .. and see if it cranks . If it does then you may have a fuel prob.
Old Oct 16, 2008 | 12:03 PM
scuba's Avatar
First things First.
Efi Fuse.
Second, Im assuming you know how to pull codes, If so, Instead of pulling codes your going to want your wire or paper clip in the FP and B slots in the diagnostics port.
If it will run, We will go from there
Old Oct 17, 2008 | 11:06 AM
space-junk's Avatar
MMMMmmm... had a 94 chevy pick'em up that did the same thing...
ended up having to pull the fuel tank to get to the puel pump because the intank sediment screen was clogged... not a very fun task...
Doug4320
Mar 24, 2018 10:11 PM
thefishguy77
Jul 30, 2015 10:59 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
