Find me an A/C discharge hose!!! Discontinued!
Hey All,
I purchased the suction hose for my '90 22RE, but was told that the discharge hose is discontinued! Kragen doesn't have 'em, Autozone sent me the wrong one (go figure), Napa's a "no." Even tried RockAuto and Toyota of Texas! I'd like to find one to complete my rebuild of the unit so there's no weak links. Ideas?
Werid, Napa still shows the part as active in their system. It prolly just hasn't been removed from the system yet if it has been discontinued
Just in case they tried to give you the run around saying "I cant find it, or we don't carry it" ect, which happens a lot. The discharge hose part number is TEM 282728. Its a spendy little jewel too lists for 103.69. (90 4runner 22re)
I can't think of any online retailers that would have the hose atm
sorry. Hopefully somebody will chime in soon that has found one.
I'll have to try again, using that part number, but HOLY SMOKES!! The stealership only lists them for ~$47.00 before the were discontinued! What flavor Kentucky jelly does that come with?
I just called my local dealer here in Ontario.
California depot shows they have them. My Price $247.40 CDN
Compressor to Condensor hose. The connection sucked, but I think he said the part number was 88723-35090.
Good luck!
Good luck!
Problem is, the orifice is in the discharge hose! They can re-use the ends, but the orifice/filter won't be included. Tried...
I "think" I might have a line on one in Tennessee thru Napa...
it's the discharge tube so it goes from the pump to the evap under the dash and just in front of the evap is the orifice tube, a.k.a. (to some) expansion valve, which holds the pressure back to help the refrigerant undergo phase change from liquid to vapor and thus get cold.
pump>discharge(high pressure) tube>orifice tube/expansion valve>evaporator>receiver/drier/accumulator>condensor>suction(low pressure) tube>pump
Well I know what an expansion valve is. My question is how did he get an orifice in the middle of the hose? I suspect the thing he is referring to is just a filter. Those are rather generic and shouldn't keep anyone from having a hose made using the old fittings.
I was told that it's an orifice, as described by Abecedarian above. Was the case on an old Taurus I used to have, and when considering just getting the hose made, got talked out of it in favor of a new piece altogether. Good thing too, as I hacksawed the old one after replacing and it was SUPER CLOGGED! Trying to avoid the same here. I guess I could be wrong, but I'm just going off of what I was told. Someone correct me if you know differently, please.
Qdude
Qdude
I'm obviously no A/C expert, but it's my understanding that introducing ANY moisture to the system is a bad idea. Besides, 18+ year old hoses should probably be changed out anyhow. I see your logic, though.
nanhodges2733
May 29, 2020 03:28 PM
Poncho0206
Jul 10, 2015 06:21 PM
