Find me an A/C discharge hose!!! Discontinued!
Old Oct 15, 2008 | 07:57 AM
qdude79's Avatar
Hey All,
I purchased the suction hose for my '90 22RE, but was told that the discharge hose is discontinued! Kragen doesn't have 'em, Autozone sent me the wrong one (go figure), Napa's a "no." Even tried RockAuto and Toyota of Texas! I'd like to find one to complete my rebuild of the unit so there's no weak links. Ideas?
Old Oct 15, 2008 | 08:09 AM
Marc's Avatar
try ackits.com
Old Oct 15, 2008 | 08:18 AM
qdude79's Avatar
Just tried there, they don't carry either. Thanks, though...
Old Oct 15, 2008 | 09:19 AM
Workhorse's Avatar
Werid, Napa still shows the part as active in their system. It prolly just hasn't been removed from the system yet if it has been discontinued
Just in case they tried to give you the run around saying "I cant find it, or we don't carry it" ect, which happens a lot. The discharge hose part number is TEM 282728. Its a spendy little jewel too lists for 103.69. (90 4runner 22re)
I can't think of any online retailers that would have the hose atm sorry. Hopefully somebody will chime in soon that has found one.
Old Oct 15, 2008 | 09:24 AM
qdude79's Avatar
I'll have to try again, using that part number, but HOLY SMOKES!! The stealership only lists them for ~$47.00 before the were discontinued! What flavor Kentucky jelly does that come with?
Old Oct 15, 2008 | 09:32 AM
Workhorse's Avatar
Yea I was shocked to see the price in the system, but that's full list so i would estimate around $80 for a normal walk in. Depends on how much they like ya at the local Napa
Old Oct 15, 2008 | 09:40 AM
Noltz's Avatar
I just called my local dealer here in Ontario.
California depot shows they have them. My Price $247.40 CDN
Compressor to Condensor hose. The connection sucked, but I think he said the part number was 88723-35090.
Good luck!
Old Oct 15, 2008 | 01:02 PM
habanero's Avatar
When we couldn't get 'em the local auto a/c and radiator repair shop would fabricate what we needed. Maybe someone around your abouts could do something like that for you.
Old Oct 15, 2008 | 02:13 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
PM deathcougar, he might have what your looking for used
Old Oct 15, 2008 | 09:05 PM
myyota's Avatar
Find a place around were you live that can make you a new hose, if you can`t find a new one anywere.
Old Oct 15, 2008 | 09:31 PM
qdude79's Avatar
Problem is, the orifice is in the discharge hose! They can re-use the ends, but the orifice/filter won't be included. Tried...
I "think" I might have a line on one in Tennessee thru Napa...
Old Oct 15, 2008 | 11:17 PM
anotherjeff's Avatar
Could you explain. "...the orifice is in the discharge hose..."?
Old Oct 16, 2008 | 05:51 AM
InternetRoadkill's Avatar
Orifice in the tube? WTF?
Old Oct 16, 2008 | 10:19 AM
abecedarian's Avatar
it's the discharge tube so it goes from the pump to the evap under the dash and just in front of the evap is the orifice tube, a.k.a. (to some) expansion valve, which holds the pressure back to help the refrigerant undergo phase change from liquid to vapor and thus get cold.
pump>discharge(high pressure) tube>orifice tube/expansion valve>evaporator>receiver/drier/accumulator>condensor>suction(low pressure) tube>pump
Old Oct 16, 2008 | 10:46 AM
Well I know what an expansion valve is. My question is how did he get an orifice in the middle of the hose? I suspect the thing he is referring to is just a filter. Those are rather generic and shouldn't keep anyone from having a hose made using the old fittings.
Old Oct 16, 2008 | 10:47 AM
I guess I should've read his whole post. he does say orifice/filter so maybe it's just a debris screen.
Old Oct 17, 2008 | 08:14 AM
qdude79's Avatar
I was told that it's an orifice, as described by Abecedarian above. Was the case on an old Taurus I used to have, and when considering just getting the hose made, got talked out of it in favor of a new piece altogether. Good thing too, as I hacksawed the old one after replacing and it was SUPER CLOGGED! Trying to avoid the same here. I guess I could be wrong, but I'm just going off of what I was told. Someone correct me if you know differently, please.
Qdude
Old Oct 17, 2008 | 10:06 AM
space-junk's Avatar
if theres a filter screening debris in there and its not "bad" just clogged, then couldnt you run water down the hose backwards to unclog it??
Old Oct 17, 2008 | 10:12 AM
qdude79's Avatar
I'm obviously no A/C expert, but it's my understanding that introducing ANY moisture to the system is a bad idea. Besides, 18+ year old hoses should probably be changed out anyhow. I see your logic, though.
Old Oct 17, 2008 | 11:13 AM
If the filter is clogged, there must be a reason for it. The filter is generally there to catch debris from a compressor failure.
MO transplant
Apr 23, 2023 11:58 AM
nanhodges2733
May 29, 2020 03:28 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
