Sponsored by: CARiD
twinsticks
Old Aug 11, 2008 | 06:41 PM
hmmwv15's Avatar
twinsticks
Would it make sense to run twinsticks on my stock 4runner t-case?
Old Aug 11, 2008 | 08:32 PM
tc's Avatar
tc
The only "disadvantages" are cost and installation difficulty.
The only real benefit is it gives you 2LOW ...
Old Aug 11, 2008 | 08:37 PM
86blue4runner's Avatar
plus it looks sweet to have em! haha just playin. so is there any difference in having 2 low and just putting your t-case in 4-low without locking the hubs?
Old Aug 11, 2008 | 08:39 PM
tc's Avatar
tc
Yeah, when you get stuck, you flip the lever to 4WD and off you go...
Old Aug 11, 2008 | 08:41 PM
woops didnt think of that. so how hard is it to install?
Old Aug 11, 2008 | 08:47 PM
tc's Avatar
tc
http://www.marlincrawler.com/htm/tra...twin_stick.htm
Old Aug 12, 2008 | 01:20 PM
hmmwv15's Avatar
I knew it would give me 2 low, I just wanted to know if it would make sense to go twinsticks with stock tcase and gears. What would it do if I shifted one lever to 2 low and the other to 4 high? would it make the rears spin slower than the fronts? Would it even make a difference?
Now that I think about it, I probably need to get sliders before the twinsticks anyway...
Old Aug 12, 2008 | 02:36 PM
Hayes's Avatar
twin sticks gives you 2 hi 4 hi 4 lo and 2 lo...nothing changes between the wheels except driven and not driven.
Old Aug 12, 2008 | 02:51 PM
waskillywabbit's Avatar
A lot of work for very little.
Old Aug 12, 2008 | 03:43 PM
DeathCougar's Avatar
Twin sticks on a Toyota case is pretty silly and pointless, in MOST applications. If you hardcore rock crawling, maybe. But for Average street driver Joe, twin sticks are a waste of money. IMO.
Old Aug 12, 2008 | 03:46 PM
AxleIke's Avatar
The other advantage is that, should you break a CV, you can drive out in low range without spinning your CV, which you cannot do by just unlocking your hubs. On our HC run, this would have been invaluable when TC broke a CV, had the CV not gotten up into his brakes. If it had been a normal break, he could have driven to a flatter area, gotten the CV changed, and been on the way much more quickly.
I have em, and love em. They enable me to unlock my front ARB MUCH easier when my drivetrain is bound up.
Shift into 2wd, still in low, and I can steer again instantly.
Old Aug 12, 2008 | 04:10 PM
dropzone's Avatar
Fossilized
binding up the front end is exactly why I am putting this in...should help till I can afford some Longfields
Front Range Off Road Twin stick, should make turning a little easier with the front locker. I like their design and workmanship better than some of the others on the market, plus the shift boot comes with the kit, not an add on like some on the market...
i have my TC out so I can add the extra case so thought now was the time to put one in, less work if I changed my mind...
Old Aug 12, 2008 | 04:20 PM
Mic09dcsm's Avatar
You don't need twinsticks for 2lo, just manual hubs
Old Aug 12, 2008 | 04:24 PM
Hayes's Avatar
yeah, but then you have to get out and lock before every obstacle and unlock after every obstacle...forget that
Old Aug 12, 2008 | 08:09 PM
AxleIke's Avatar
no. Sure, you are only driving the rear wheels, and you can do the locker thing, but not the broken thing. With FF fronts, you can just unlock hubs, go to two low, and drive out on broken front diffs/axles, etc...which is more likely than a rear on an IFS truck.
Old Aug 12, 2008 | 08:18 PM
strykersd's Avatar
Wow I didn't even know we had these for our Toyota's. I've been considering installing a aussie locker in the front of my 4runner, but thought I'd need to convert to manual hubs to make sharp turns. The hubs would probably set me back $100, so $190 for this seems like a smoking deal. I've always liked the convience of my auto hubs. Plus the extra $90 is worth it for the coolness factor of twin sticks.
Old Aug 12, 2008 | 08:44 PM
tc's Avatar
tc
Mine bind up pretty bad and are often quite hard to shift from 4WD to 2WD ... I would hate to be counting on that to be able to turn...
Old Aug 13, 2008 | 03:16 PM
hmmwv15's Avatar
This is exactly the response I was looking for.
So without having dual cases or a locker in the front, it really makes no sense to run twinsticks, unless I want 2 low. For now I'm calling 2 low a $150-$200 option so that really doesn't make sense.
6th Gear
19
Dec 10, 2019 07:31 AM
dasrunner
Apr 13, 2012 06:42 AM
SlightlyModified
Feb 25, 2007 03:32 PM
Napoleon047
Dec 16, 2005 09:13 PM
JoKEpLaYeR
9
Jun 21, 2004 03:35 PM
