Pre 84 Trucks 1st gen pickups
seat swap
Old Jul 12, 2008 | 10:47 AM
rottenagenda's Avatar
seat swap
So i dislike my after market cheapo racing seats. what is a easy swap for buck seats?
i just want some cheap bucket seats.
if any one has some pic that would be great.
thanx
1979 toyota 4x4 pu
Old Jul 12, 2008 | 01:00 PM
Hayes's Avatar
let me know what you are going to do with your old seats...
Old Jul 12, 2008 | 02:38 PM
85toy's Avatar
try the search button. this has been covered tons of times.
Old Jul 13, 2008 | 06:20 PM
82greenbeast's Avatar
use old civic si seats.
Old Jul 14, 2008 | 08:56 AM
dropzone's Avatar
Fossilized
$50 bucks
Found a set of 93-94 Integra seats that were a little dirty but overall excellant shape:
there is a second hole about 1.25" over from the stock front outside mounting hole that lined up just about right, enlarged it just a hair and was able to use the inside front stock mount:
just had to cut off about the lower .25" or so of the stock bracket to allow it to sit flat on the floor.
I think that being able to use the stock front holes makes the install much more stable and install went very fast...
outside rear mount came up with something similar to WSUWeston's brackets:
The rear inside mount is flat, so ended up using the old stack of washers install method. Used grade 8 fender washers on the underside so that should help spread the load.
Old Jul 17, 2008 | 12:03 PM
Scooby098's Avatar
I have a question I went to the junk yard and got some civic seats didnt know there any other kind anyway small town not alot of options so they really dont bolt up execpt for maybe one think its worth makeing them fit ? cause they have no rips or nothing and look like new 91 civic seats there like an inch off the hole .
Old Jul 17, 2008 | 01:50 PM
refried's Avatar
I'd start with using some punctuation marks when writing, Then get the drill, make some holes and bolt your seats in.
Old Jul 17, 2008 | 02:18 PM
83's Avatar
83
I love it.
Old Jul 17, 2008 | 03:15 PM
Scooby098's Avatar
sorry lol I use worse grammer than a 5 yearold some days. I got one bolted in got to make the bracket above, And I used a piece of Pressure treated 2 by 2 to use as a spacer to keep the seat level instead of a bunch of washers...
Old Jul 17, 2008 | 08:47 PM
dropzone's Avatar
Fossilized
2x2 PT: Sounds like the Civic seats are a little different that the acura seats. I only needed to come about 7/8" of an inch on the inside rear brackets.
post some pictures of the finished product. If they are like mine, it feels a lot better driving the truck
Old Jul 17, 2008 | 09:28 PM
07sbock's Avatar
I put some 95 4runner seats in mine! 100 bones at the junk yard, they are great!
Old Jul 22, 2008 | 05:26 PM
Scooby098's Avatar
k heres mine. I had to redneck it a bit, Considering I dont have much laying around so I used some pressure treated 2/4 for spacers .they are alot better than the bench just need some goretex seat covers lol laters.
icentropy
Sep 16, 2020 02:47 PM
jasonty
41
Dec 23, 2018 01:00 PM
noahstancik
Jul 17, 2015 05:38 PM
icentropy
Jul 9, 2015 02:12 PM
garagespace
Jul 9, 2015 08:37 AM
