Suspension Parts ID - Help Needed, clutch Question
Old May 31, 2008 | 10:09 AM
warriors_03's Avatar
Ok everyone, need some help here IDing 2 suspension parts (I think they are the same, but want to be sure) and the haynes manual is not helping much.
I was under giving her a check-up and found these and I think they need to be replaced. I need help IDing the red boxes, and on the rear picture, whats in the blue box is leaking greese. The rubber boots on both sides are torn on the rears. The rubber on the tops of the fronts looks to be wearing a bit to me, but I don't know.
Second Question:
While I was under, I was looking at the clutch slave, and pushed on the fork end, pushing the cylinder rod inward (towards the front of the vehicle). And to my surprise, I was able to move it, and it would then return to its original position. Is this normal or do I have a master/slave issue somewhere. I would think that I wouldn't be able to push it in like that because of the fluid back pressure but I might be totally wrong. Thanks in advance for the help guys.
Mark
Attached Thumbnails Suspension Parts ID - Help Needed, clutch Question-rear.jpg   Suspension Parts ID - Help Needed, clutch Question-front.jpg
Old May 31, 2008 | 10:15 AM
kmcaprice14's Avatar
sway bar endlinks.... I need some new ones too. Sometimes they are sold as sway bar bushings or sway bar links. Yours don't look too bad... are they leaking at all? Any grease coming from the rubber boots?
Old May 31, 2008 | 11:00 AM
yes on the rears, and the rears are torn....
Old May 31, 2008 | 11:17 AM
same here...then they are gonna need replacement when you get the chance. I've been looking for some replacements for a while... but they are $90 each from toyota
Old May 31, 2008 | 12:17 PM
Maj's Avatar
Maj
The clutch hydraulic system is fine. You can do the same thing with brake calipers by pushing in on the piston.
GreenLion
Jun 7, 2021 10:49 AM
voiddweller
19
May 2, 2016 09:10 PM
Niameyrider
Jun 25, 2015 05:50 AM
HALMAN
Jun 14, 2002 09:02 PM
