1st gen Runners w/sunroof
Old May 18, 2008 | 08:42 PM
Djlarroc's Avatar
Exclamation 1st gen Runners w/sunroof
Can someone tell me the dimensions on their Runner's sunroof glass? I came accross a nice deal on a brand new aftermarket sunroof w/hardware. There are 2 sizes. So I can see which is a closer fit. Thanks
Old May 19, 2008 | 10:44 AM
Djlarroc's Avatar
Coulda swore there was at least 1 person with a sunroof in their Runner.
Bumpity
Old May 19, 2008 | 10:59 AM
881stGenRunner's Avatar
Im in school now, but when i get out and get off work ill get the outer and inner dimensions for you.
Old May 19, 2008 | 11:28 AM
Djlarroc's Avatar
Thanks!
Old May 19, 2008 | 12:54 PM
anotherjeff's Avatar
If you're installing an aftermarket sunroof , why is the OEM sunroof size important?
Old May 19, 2008 | 01:29 PM
4Crawler's Avatar
The glass on my '85 measures approx. 36.5" x 19.5"
Old May 19, 2008 | 08:33 PM
Djlarroc's Avatar
Thanks 4crawler!!
The 2 sizes are 15 1/4" x 29 3/8".
And, 17 1/4" x 33 1/2"...I'm thinking the latter.
Does anyone have pics of what their sunroof looks like on the inside? Just trying to get an idea of how I'm going to have to do this.. And of course their will be a write up as well.
Thanks
Old May 24, 2008 | 12:36 PM
kcrunner's Avatar
Here's a pic of my sunroof. It's all I've got for now, hope it helps.Name:  toyota016.jpg
Old May 24, 2008 | 03:32 PM
Matt16's Avatar
I wonder how hard it would be to install a sunroof on a second gen?
Old May 24, 2008 | 03:38 PM
4Crawler's Avatar
I installed one (flip up style) on my old VW and it was not too hard. Just lay out the template on the roof, cut out the opening in the sheet metal. Repeat for the headliner then put in the frame and glass.
Old May 24, 2008 | 04:27 PM
Noltz's Avatar
Not hard at all. IIRC, there's no wiring to get in the way unless you're going back far enough that relocating the light is necessary. All kits come with instructions.
Old May 30, 2008 | 08:21 AM
Djlarroc's Avatar
Ok, so I bought a sunroof kit on eBay. It's brand new and comes w/the hardware. It's a 17 1/4" x 33 1/2". Here's some pics.
Old May 30, 2008 | 08:52 AM
pepsibluefloat's Avatar
When i did mine in my f150 you popped out part of the box it came in to use as a template for cutting the hole in the roof....looks like a pain to get the hole exactly right just using the sunroof frame..
Old May 30, 2008 | 09:35 AM
89silverpu's Avatar
Make sure you measure like 100 times then cut once lol that would suck, I think I saw a thread about some guy cutting too large a hole in his roof and it wasn't an easy error to fix...
Old May 30, 2008 | 10:41 AM
Djlarroc's Avatar
Thanks for the pics pepsi. Do you remember what you used to cut into the roof? And how about from in the cab? To not tear up the liner so much..
Yeah, I read about that guy too. He had to buy a bigger sunroof. Ouch! Yeah, this is my biggest mod yet, so I'm for sure going to measure many many times before I cut. And of course there will be a writeup.
Old May 30, 2008 | 10:56 AM
Matt16's Avatar
I'd use a box cutter to cut the head liner, and a plasma cutter (ideally, but not necessary), you could use a reciprocating saw or something as well.
If I remember correct, the factory sunroofs have a feature that allows the glass to slide back into the head liner. Do the aftermarket sunroofs have this as well?
Old May 30, 2008 | 01:15 PM
Djlarroc's Avatar
They may, but not this one 'cuz it's a pop-up.
Old May 30, 2008 | 01:20 PM
4Crawler's Avatar
I think all the 1st gen sunroofs were pop-up type, at least the one on my '85 is and it is original.
DeathCougar's Avatar
Why dont you just take your top off?
Never understood the need for aftermarket sunroofs in 1st gen 4runners....
But since you asked...
Old May 30, 2008 | 01:21 PM
That is correct, 84-88 trucks and 84-89 4runners were pop up only. Since it was a 2dr, and had a removeable top, there would be nowhere for the glass to slide to.
