1991 4Runner SR5 - won't turn over...
Old May 15, 2008 | 02:22 PM
B45's Avatar
B45
got an old '91 4runner as a bush beater and ran into some trouble getting it started again. A friend of mone tried to boost (battery dead) at night and put the cables on backwards and it hasn't started since. If we hook up the booster cables and spray some gas into the air intake it will run off the gas but then die out. Tried putting on a new fuel pump, still no luck and checked the fuses too. Would the EFI relay fuse under the hood be the issue? Or the sender on the tank? Something else? Just frustrating that I can't get the pump pumping because it does run if you feed it directly in the air intake....
Old May 15, 2008 | 02:25 PM
4Crawler's Avatar
Try the fuel pump test jumper:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Could be the fuel pump switch in the Air Flow Meter went out:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
And for sure, check all the fuses under the hood and under the dash.
Old May 15, 2008 | 02:41 PM
abecedarian's Avatar
Check the fusible links in the wires coming from the + terminal of the battery.
Also, may be an ECU fried from the reversed voltage.
Old May 15, 2008 | 03:01 PM
wardriver's Avatar
True but probably wouldn't run off of the ether if it was. Is your fuel pump getting voltage?
Old May 15, 2008 | 03:04 PM
thanks wardriver, I didn't think of that.
check the fuel pump operation by simply inserting the key and turning it on, but not starting it. If you hear the fuel pump run, it's getting voltage. If not, you can connect a voltmeter to the FP terminal inside the diagnostic connector and the - terminal of the battery- you should get voltage for about 2-4 seconds when the key is turned on.
arlindsay1992
Jan 23, 2024 01:34 PM
toyota32
Jul 6, 2015 05:42 PM
CJ94yota
Jul 3, 2015 10:14 PM
aciorba23
Jun 29, 2015 04:18 PM
