Good trip gone bad.
This weekend my family and I when up to Denver to visit my grandparents and I took my Runner. The trip there and while I was there the Runner ran great. I even got to go wheeling in the mountains.
On the trip home, in the middle of Kansas, my battery light and brake light came on. I stopped and checked everything out, it seemed there was no reason for them to be on. Later down the road, just after getting into Oklahoma things got weird, my radio just shut off, and my anti-lock brake light came on. Then further down the road my tach quit, the battery meter was WAY low by then. The truck still ran for a while then it would kinda stall when I tried to accelerate so I pulled over and stopped. My guess is the alternator is bad, but I'm no mechanic. Any Ideas??
Sorry it's kinda long but I'm kinda pissed.
My 2nd generation had the same symptoms and it was the alternator. Fortunately, I limped home and not a minute too soon.
If you have another vehicle to use in the meantime, check Mralternator.com. They sell direct bolt on high output alternators for the 3.0V6. It's cheaper than the dealer and a little more than the local stores.
save lots of money
just replace the brushes! I have found out that the brushes on almost all of the toyotas are the same and the regulators with the same connections (plug round or oval) are the same. the alternator on my 87 4runner (minus pully) is the same as the one on my 93 celica. and i replaced the alternator on the truck with one from a 95 4runner (different plug) by using a regulator from an alternator from the celica. to swap the brushes takes about 3 minutes (with the alternator out of the truck)
good luck!
David
good luck!
David
This is a side-note FTY for future alt troubles.
IF (big IF) you carry a Jumper Pack (little battey with jumper cables) and this happens to you, just plug the cig. lighter chager cable in and you can drive like normal for a long ways. Not good for night drives, but this got a friend home (about 50-75 miles) one day.
If you replace the brushes you should turn the comutator shaft or they will not make good contact until they wear in.
I am with you 96 runner, get a new one unless you are hard on cash.
I replaced the alternator and got my baby home today. Installing the new alternator was a breeze. Now everything works and at over 200K she's still running strong.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
skoti89
Jul 6, 2015 07:45 PM
