3000 rpm screeching noise
Old Apr 11, 2008 | 11:39 AM
joshuapc's Avatar
my 22re screeches once the rpms reach 3000 rpm and continues at higher rpms. could it be a loose belt? anybody else have this problem?
Old Apr 11, 2008 | 11:43 AM
machabees's Avatar
loose belt is certainly the first thing I would check.
Old Apr 11, 2008 | 12:30 PM
norcalsvx's Avatar
squeeky/loose belt check for glazing on belt
Old Apr 11, 2008 | 12:35 PM
rdlsz24's Avatar
If you want to be sure it's a belt take both (3 if you have AC) off and run your engine for a minute. It won't hurt anything if you don't run it for an extended amount of time. With the belts off see if it's quiet. This is how I determined my wife's car had a bad idler pulley.
Rob
Old Apr 11, 2008 | 08:28 PM
joshuapc's Avatar
yeah it seems to be the source. im thinking its the powersteering. whats glazing?
Old Apr 11, 2008 | 08:33 PM
cutboggers's Avatar
check the power steering tensioner pulley. Sumtimes the bearing goes out causing squeaky belt.
cheap to replace.
glazing would be shinyness on underside of belt meaning it has been slipping.
Old Apr 12, 2008 | 03:15 AM
ovrrdrive's Avatar
Rob
This is where I'd look first as well...
The idler pulley's are pretty cheap and easy to replace, and they go bad all the time. They make noises like you describe when they go out too.
Old Apr 13, 2008 | 08:08 PM
hudsdad08's Avatar
Sorry I dont mean to hyjack this thread but im having the same problem with my 4runner, when i first start it up it will run fine for like 5 minutes or so and then it starts making a loud squealing sound and it continues until it warms up but once its warm you can drive it all day and never hear again. I replaced all 3 belts and i also had to replace the harmonic balancer due to being bad. Could anyone maybe tell me what this might be cause its really loud and annoying.
donovanloj
Aug 16, 2015 10:07 AM
norcal98
Aug 10, 2015 06:20 AM
256mbaker
Jul 31, 2015 06:45 PM
Athansinis
Jul 27, 2015 08:38 AM
91yotapup
Jul 27, 2015 07:19 AM
