wont start
Old Apr 8, 2008 | 06:01 AM
89yota_mudrunner's Avatar
wont start
i have an 89 V6 pickup and about a month ago i was driving down the road and hit a massive frost heave and the truck just shut off. i tried starting it and it would turn over but there was no spark. i checked all the wires and everything seemed fine. i just put in a new ignition coil cause there was no spark coming from there but still it wont fire up. any ideas?
Old Apr 8, 2008 | 05:54 PM
i know this is probly something electircal...any ideas?
Old Apr 8, 2008 | 05:57 PM
bigt's Avatar
how can you hit a massive frost??
are you still not getting any spark at all???
how are your plugs?
Old Apr 8, 2008 | 06:13 PM
its a frost heave...when the frost makes a bump in the road.
the plugs are farely new.
i tried starting it after i put the new ignition coil on and it turns over like normal but obviously there is no spark if it doesnt start. is that correct?
Old Apr 8, 2008 | 07:10 PM
machabees's Avatar
not necessarily.
there are many reasons why an engine won't star even if it has spark.
spark is very important. a simple way to test it is to pull off one of your wires put a spare (and Known good) spark plug in it, lay it against your block so it has a ground and turn the truck over to see if that plug sparks.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
