Knock sensor signal ?????
Im getting a CEL for knock sensor signal, my engine seems to be running fine. what does this all mean? should I just replace my sensor. what am I risking if I ignore it for awhile?????
Big chore, assuming your sig line is correct, yours will be under the intake manifold. Dont even think of doing it without replacing the wire also (short pigtail). Its almost alwasy the connector (corrosion) and sometimes the wire in the harness, but never seen a bad knock sensor yet.
Ok I need help! I thought I new where this sensor was at but I cant seem to find it ???? Is it near the distributer??? To top it all off while investigating I found a large tear in my CV boot grease everywhere!!!
it is under the intake, you have to take the upper plenum off then remove the manifold, it will be right there, do yourself a favor and replace the sensor too, i made the mistake of not getting the sensor(just did the wire), and now after all that work i still get the same code!! The first time you get into it, it will b a apain in the butt, and prob take several hours, but after you figure out all the shortcuts it shouldnt take more than 4-5 hrs...goodluck
djohnson13
Sep 4, 2015 12:35 PM
Flossy
Aug 5, 2015 05:14 PM
