06 Tundra Rims Dont Fit On My 00 4runner
Old Apr 1, 2008 | 09:05 AM
mattyk24runner's Avatar
I bought a set of 20" Toyota Tundra rims and tires off a guy.I tried to put them on but they didnt go all the way on. Does the tundra have a smaller hub than a 4runner? Really confused??
Old Apr 1, 2008 | 02:43 PM
Taro's Avatar
I'm running stock '06 Tundra 16's on my 2000 4runner. Maybe they were not on a Tundra and came from a Chevy and he lied.
Old Apr 1, 2008 | 02:59 PM
Good call, I was looked on the back of the rim it didnt say toyota. Thanx
Old Apr 1, 2008 | 05:36 PM
bigarms23's Avatar
you can always remachine the wholes on the rims to make them fit
Old Apr 2, 2008 | 06:30 AM
dirtoyboy's Avatar
live and u learn right? maybe u will do a little more research next time before whipping out that wallet
Old Apr 2, 2008 | 06:35 AM
rdlsz24's Avatar
Try before you buy lol. I'm sure you can make them fit.
Rob
Old Apr 3, 2008 | 01:40 PM
Adam F's Avatar
Toyota never made a 20" rim
Old Apr 3, 2008 | 01:46 PM
Belize Off Road Team's Avatar
Adam F. Toyota actually did and does make 20" rims.
http://toronto.kijiji.ca/c-cars-vehi...QAdIdZ38859219
http://cgi.ebay.ca/20-Toyota-OEM-Chr...713.m153.l1262
and most of the new 07/08 Tundra's come with 20". BUT most of the Toyota 4x4's have 6 lugs except new ones, they now come with 5 lugs.
Old Apr 3, 2008 | 02:12 PM
xcmountain80's Avatar
Well dang. Didn't ou say the center hole was different?
Aaron
Old Apr 3, 2008 | 02:33 PM
Adam F's Avatar
Oh. Diddnt know Tundras came with 20's.
Old Apr 3, 2008 | 02:46 PM
The more you know....CAUSE KNOWLEDGE IS POWER!
Old Apr 3, 2008 | 05:19 PM
My theory is the hub end cap on the 4runner and taco are bigger than that of the Tundra. Because the 4runner and taco can utilized manual hubs where the tundra cannot and to my knowledge has never had or even been able to swap to them resulting in a smaller dia. hub end which makes those damn rims not fit. Now what can you do. Well you can machine them from the back leaving the mount surface for the center cap intact and kabam they will work. I use wheel spacers and found out that I can run center caps even with my hubs.
Aaron
Old Aug 17, 2008 | 07:41 PM
yomerocs's Avatar
08 tundra rims
I'm taking your offer...
I want to install tundra 2008 18" rims on my 05 tundra and I understand I need a conversion kit, because of the 5 hole 6 hole difference...
What kit is that?
Also
1-How will that affect the tire pressure sensor?
2-In order for the odometer to show mileage correctly, what is needed?
Thanks
Old Aug 18, 2008 | 05:44 PM
Jay351's Avatar
Uhm. No. You don't convert lugs to run a stock wheel. Get wheels that are the correct bolt pattern.
Jun 1, 2021 01:51 PM
icentropy
Jul 9, 2015 02:12 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
