What are These Buttons?
Old Mar 11, 2008 | 05:19 AM
maximum13's Avatar
This is a 2001 4runner Limited. I see through the steering wheel a button where the RR Diff Lock woudl be (but I thought that wasnt an option on 01's), and then to the left, two more buttons.
What might these be, based on teh year and the locations?
Attached Thumbnails What are These Buttons?-286290_99f25f11-bebe-48c4-b556-b8015adcc06f.jpg
Old Mar 11, 2008 | 05:28 AM
Rock Slide's Avatar
I'm willing to bet, the button where you think the RR Diff lock switch is, is actually the Center Diff Lock switch (same switch on mine). This switch looks the center diff when in 4wd. '01 and '02 4Runners had no oem rear locker option.
The button to the far left of steering wheel looks like the oem alarm light.
Can't tell what the other switch is...too hidden.
Edit: here's a picture of my center diff switch:
Old Mar 11, 2008 | 05:44 AM
Cxrazy's Avatar
what does center diff do compared to a rear locker?
Old Mar 11, 2008 | 05:50 AM
Bighead's Avatar
If you hit the button on the transfer case shifter you have put it into All-Wheel Drive. Once you hit the Center Diff Lock button you put it into true 4-Wheel Drive.
Old Mar 11, 2008 | 05:55 AM
Cxrazy's Avatar
oh... My 98 just has 4wd, or not 4wd. haha
Old Mar 11, 2008 | 06:04 AM
dirtoyboy's Avatar
Originally Posted by Bighead
Once you hit the Center Diff Lock button you put it into TRUE 4-Wheel Drive.
Really? Then I guess i have no reason to look at lockers for my front diff anymore......
Old Mar 11, 2008 | 06:15 AM
Spence1016's Avatar
its not the same thiing as having a locker in the front or rear diffs. the center diff lock means an even 50/50 distribution of torque to the front and rear
Old Mar 11, 2008 | 06:52 AM
Bighead's Avatar
FYI...The 2001 Limited he originally asked about has Toyota's electronic traction control (ATRAC). Not as good as the dual ARBs I have but better than standard open diffs.
Old Mar 11, 2008 | 07:16 AM
Chrisnxl185's Avatar
Is it true that most transfer causes split the torque 50/50 when you put them in 4low? I remember someone telling me that.
Old Mar 11, 2008 | 07:30 AM
Godzilla's Avatar
The two buttons grouped to the far left are for heated seat controls. The one more to the centre is the centre diff lock
Old Mar 11, 2008 | 09:08 AM
rearviewmirror's Avatar
Center diff lock provides a 50/50 torque split between the front and rear. A rear locker does just that, locks the rear axle.
Old Mar 11, 2008 | 09:58 AM
dirtoyboy's Avatar
Have you checked your owners manual, maximum 13?
sounds dumb, I know.
Old Mar 11, 2008 | 10:28 AM
racinkid13's Avatar
ah, always filled with wholesome goodness.
Old Mar 11, 2008 | 10:29 AM
redpim1's Avatar
From: From Louisiana, Work in Iraq, live in the Philippines
Um... I'm taking a wild guess that you can read because you are posting here... RTFM!
That is all I have to say....
Old Mar 11, 2008 | 10:31 AM
unclejstoy's Avatar
well I don't know how the new manuals are on the new toyota's.
But from working On equipment catepiller /genie the Operators manuals are very detailed on the operators station including butten's/switches
Old Mar 11, 2008 | 11:19 AM
Rock Slide's Avatar
Just to point out, he never said either way if the vehicle belonged to him or not. It could simply be a 4Runner he's found for sale online that had pictures included in the ad. (Most people taking pictures of their vehicle, do not often take such a shot as what he's posted. IMO, it looks like an ad shot.)
2nd, if this 4Runner does happen to belong to him, chances are the manual has since been lost.
And yes, unclejstoy you are correct right. The manual is very specific as to what the Center Diff lock switch does.
Old Mar 11, 2008 | 11:47 AM
Whitey13's Avatar
Judging by the context of his post, I assume (as Rock Slide pointed out) that this is not his truck. If such was the case he would have taken a more accurate picture.
Notice the post counts on those guys??
Old Mar 11, 2008 | 12:00 PM
dirtoyboy's Avatar
the board is being infested with TROLLS!
Old Mar 11, 2008 | 12:02 PM
unclejstoy's Avatar
Not the words i would use
I tried google for a operators manual no luck so far
Old Mar 11, 2008 | 12:35 PM
AxleIke's Avatar
The question has been answered. They are seat heater controls.
