2003 Roof Rack Removal
ok i really dont know what you mean by removing the roof rack cause i would be alittle worried. Do you mean by just removing the two bars that go along the sides of the 4runner and the cross members. Or are you including the brackets to????? I dont know how the brackets are attached to the roof but i would be alittle worried to remove them. (water leaks) Also i know for a fact the where the roof rack is attached to the roof, the far end of it that are a smooth curve, that whole piece of plastic pops out. ive seen it off just never removed it myslef. Then i would assum there is just one bolt for the bar that goes along the 4runner. If anyone removed a black roof rack i want it I dont want a silver roof rack and have never gotten around to chanign it.
Chris
Chris
Figured it out
Thanks for the link Calrockx, I was able to remove the 2003 roof rack, the end caps do pop off, its just a little tricky you have to know where to apply pressure. There are two bolts under each end cap that hold the rack on, and that's it.
I used a long flat dull kitchen knife, but you might want to use something thats made of hard plastic, or a flat screwdriver. Also, might want to put down some cloth around the rack as a precaution, I slipped and put a little scratch on my roof paint. If you stand looking at the roof rack and the plastic end cap(looking at the front door) you'll see that you can slip a thin object in behind the outward facing side of the cap, parallel with the roof. I slipped the knife in pretty far, near the roofline, and then pushed the knife handle AWAY from me and it popped off the first tab. I then put the knife along the bottom front of the end cap(as there's now a space), in between the bottom edge of the cap and the rubber skirt, and used it like a lever to lift the end cap and pop off the second tab in the front. Then you just pull it off. You need a torx bit(Star shaped bit) to unscrew the bars, I think both a #25 and #30. I will try to post some pictures later if I can.
can you take some pix after the rack is removed? I'd like to see the pix of the base of the roof rack on the roof itself.
i only ask this because i currently have the yak megawarrior on top and i'd like to mount it directly to the roof instead of using the roof rack itself. so pix would be greatly appreciated
Hey Skip, check your pm!
Good Times, I'll take pics in the morning. My daughter has me for the night, Shes leaving for a week with her softball team tomm. Afterwards, I'll post some pics of the rack mounts!
Tell you what, don't grab the end caps too hard. I was trying to get up to wash the roof and one of them came off. I almost broke my freakin' neck. I think the '03 would look weird w/o the rack...
Why you want it off skip ? just replacing it or losing it alltogether.
They were actually pretty easy to remove. The mounts themselves actually just drop into the holes in the first pic. I did notice that there is a difference between front and rear filler plate on the underside of the caps. Its the part facing rearward on the front and facing forward on the rear. I'll post it as the last pic.
sweet!!! thanks for the pix!
now all I have to do is find someone to make me some perm mounts to use w/ my yak megawarrior
since the factory rack doesn't provide much support bolting it directly to the frame will be better
someone wanna fab me some stuff? hehe
...someone wanna fab me some stuff? hehe
the abs plastic roof rack is suppose to sustain weights up to 75#.
its okay for limited use but what I'd like to do is be able to throw 150-250# (just so I know i can do it!
anyway.... thule has mounts for the bmw 3 series that bolts on to the roof so hopefully they'll have something similar for the 4runner
)anyway.... thule has mounts for the bmw 3 series that bolts on to the roof so hopefully they'll have something similar for the 4runner
Edge, I will take some pics of it without the rack, won't get them posted until later today though.
I replaced the mounts into the spaces. I should be putting the rails back on as soon as I get it. Figured there was no need to put something else in there.
02Runner
no problem waiting, just want to see how it looks without the rack.
What do you mean by your putting the rails back on, are you getting black ones or did you just want to remove the cross bars
