4WD light flashing - No 4WD
Got a bunch of ice around here and tried using 4wd and got nothing. Just the light flashes....now all of the time.
I can't get it to go off and I am still in 2wd.
Its a 99 4Runner with 84K miles. I disconnected the batteries for alittle while thinking it was a computer issue...but it didn't help. Does it sound like the actuator ?
EDIT
Disregard, I just found some info on the search...
Thanks.
EDIT
Thanks.
here are the threads I found...seems to be alot of these problems.
https://www.yotatech.com/search.php?searchid=4310147
Humm, not sure why that wouldnt work, here is another.
https://www.yotatech.com/search.php?searchid=4310586
Still doesn't work.
You have to post the link to the post. I think you're trying to post a link to the search page.
Did you try revving your engine with the 4WD pushed in. Since it does work on a vacuum system, it helps to rev. Hope you get it figured out, though.
Well, all I did was type " 4WD light flashing" in the search box and got a handful of results.
Doesn't appear its going to fix itself, I've tried time and time again putting it in 4wd with no luck....light is still flashing and no 4WD.
Lots of posts about this already. This is the thread I used to fix my problem.
https://www.yotatech.com/forums/f2/4...er-ltd-131201/
I've been out of the 3rd gen game for a while now.
I'd wait for some of the guru's to post up.
Sorry I couldn't be of more help.
Fink
If I get a break at work this evening, I will take a peak. BTW= the ride into work today with the new MAF is a world of difference!!! I should have swapped that out 25K miles ago
The flashing 4WD light flashing on and off is pissing me off though....
I'm glad that worked out, it's a good feeling when you finally figure out what was wrong and get it fixed.
It would annoy me too...
Fink
