thinkin about this lift
I was looking at Fat Bobs Garage at th e lift kits he offers. They have a 2.5 front and 2.5 rear spacer kit,Its only 115.00. has anybody set up like this i dont have 1200 bucks for the Sonoran set up right now. I like doing things right but this lookreally simple and should tide me over for a year or so. I dont do much hard core offroading, just what needs to b done like hunting and maybe trail rides in the mountains once or twice a year. They also have a diff dro[p kit for 20 bucks. What do yall think
You could piece together a lift and have it come out to less than Steve's kit. Ie, find someone that lifted their tundra and use their springs. Usually they are just taking up space in someone's garage and they let them go cheap. Look at all the lift options before you buy some cheap kit to "get you by" this is your suspension we are talking about here... If the truck isn't your DD then I guess you could do something cheap, but you do get what you pay for...
Arent you just setting everything down on top of the spacers? I cant see that much of a spring rate change.If you wedge the spacer into the spring i can see that,that wouldnt be good. Unless im not seeing it straight just setting the runner down onto a higher point doesnt seem like it would change spring rates and comp.
many people argue that it is better to wait and get real springs than to use spacers due to the "cheapness" of how they work. Spacers don't compress your springs, you are right. They do make you need longer shocks still... I wish I had just gone with springs, but I am running spacers (for the last 2 years) and still haven't bought the springs (or shocks) like I've been meaning too. You will still need a couple little things, and should still do the diff drop option.
SO in the end, spacers DO NOT change your spring rate, only a different spring will change spring rate
Ah, top outs are better, but I don't know if your going to be able to get as much lift as you are wanting out of just a top-out. Personally I would just do a body lift at first since that is in the same price range. That way you will already have it when you add the suspension. I personally think for our IFS rigs that a mixture of suspension and body lift is ideal b/c a body lift keeps the center of gravity low while allowing for bigger tires (higher diff clearance) while the suspension gives you more flex etc. Anything over 2" I would say is too much but if you keep it in the 1"-2" range you should be good. Not to mention it makes working on it much easier...
my .02
my .02
talk to the guys at trdparts4u about the lift/spacers...they have been very helpful with my decision making, they've answered all my questions fast and I haven't even spent a dime there...yet. Just one man's opinion
With a body lift i have noticed they dont look as bad as on alot of trucks but it leaves the hitch hangin down. I guess that could be fixed, i dont like b/l.
I know i would run spacers atleast a year, but if i wasnt having any issues i may use them longer. I have brand new 265BFG a/t so i dont want it so high i need new tires,so thinking about that i may run spacers until i wear out the 265 size tires. I just want some space in there so it doesnt look so stock.
Thank for the input so far
The OME lift is on the stiffer side but if you choose the correct springs and use their shocks its not bad. Hell, it was the standard for many years until Steve and Andy started playing with the OEM Tundra stuff. The only thing is you have to use their shocks b/c their setup uses stiff-er springs and softer shocks. I had the Stiff springs with the HD bilstein shocks and it rode stiff for most. I personally loved it b/c my 98 was my dd and on the street 90% of the time, but I'll admit it was too stiff for some. IMHO, I would never run a super soft setup on the street if my truck was my DD but it does function/flex much better off-road when it is. I hear ya about only having a body lift, but its your truck... at the end of the day its totally up to you!
Never heard of that lift, but i get what you're saying on wanting something for now. I've learned doing it that way has lead to doing it over again.
..but x2 on Turboale's advice on shop around you can do a lift for around the same price with other guys stuff lying around--most of the guys here aren't really selling their stuff to make a big profit so it could be something to look into.
The OME kit would work for awhile who knows by time i run it awile i may be ready for sas. This is used as a dd but doesnt have to be. The sas look pretty sweet and clean if done right then i could have locking hubs,springs and all that good stuff. I wonder if anybody has any long term use reports of daily driving that setup? one thing at a time tho i maynever sas i hate to mess up a really nice dd , i probably would never go hardcore offroading enough to need it,i just like it and i looks cool( and functional too)
Look at the thread right above yours
https://www.yotatech.com/forums/f2/0...prings-137064/
$691 shipped through rocky-road.com. 2.5" lift. That's what I'd go with. Steve's kit is nice, but with the savings through OME, I can get sliders, too!
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
