Boken key
Old Jan 29, 2008 | 02:51 PM
tim3393's Avatar
Boken key
Does anyone know how to get a broken key out of the ignition. I cant get anything in there to grab it. I tried to tke it out but it eem like it is riveted on to the steering colum. I can still turn the ingnition, but I don't want to leave it like that,
Old Jan 29, 2008 | 03:02 PM
jd20phill's Avatar
little bitty screwdriver perhaps? I used that and a small set of needle nose pliers to get a key out one time. Good Luck!
Old Jan 29, 2008 | 03:12 PM
grant526's Avatar
I used a pocket knife on mine once.
Old Jan 29, 2008 | 03:19 PM
tc's Avatar
tc
Unbolt ignition lock cylinder.
Disconnect wiring in back.
Install new ignition lock reverse of above procedure.
Old Jan 29, 2008 | 03:26 PM
Jay351's Avatar
get some very thin nose pliers. Perhaps a snap ring plier since they have very small tips.
Old Jan 29, 2008 | 03:29 PM
TOY89's Avatar
This happened to me at work. I had to call a locksmith.
Old Jan 30, 2008 | 06:28 AM
GSGALLANT's Avatar
One of those strong pickup tool magnets might work. I have one at home. It's about the size of a 5/8" nut, and will lift 8 pounds. That may work (if your key will stick to a magnet, that is).
Other than that... a dental pick, maybe?
Old Jan 30, 2008 | 11:06 AM
gravy's Avatar
that little hook/pick set that snap-on sells works too. i've used that before.
Old Jan 30, 2008 | 08:38 PM
gametom's Avatar
mine's stuck in there good too i have just learned to live with it
Old Jan 30, 2008 | 09:16 PM
Jay351's Avatar
How the heck did you break off the key anyways?
Old Jan 30, 2008 | 09:29 PM
infiltrator's Avatar
he saw a hot girl in a toyota and said DAMNNN and jammed it in and snapped his poor thing off.
Old Jan 30, 2008 | 09:31 PM
Jay351's Avatar
Old Jan 31, 2008 | 02:56 AM
tim3393's Avatar
My 16 year old did it, so he probably did see a girl and broke it off. I was trying to figure out how to get the igniton out, it seems to be riveted on the steering colum.
Old Jan 31, 2008 | 03:34 AM
misterzee's Avatar
There is a dimple on the ignition assembly in line with the lock cylinder. You push in with a small pointy tool and then pull the cylinder out completely. That makes micro surgery easier. Depending on what vehicle you have, it might be easy or difficult to get the necessary plastic pieces removed to get at the dimple. You don't have to remove the ignition assembly though.
Old Jan 31, 2008 | 05:09 AM
4bows's Avatar
Depending on how much key is exposed...is there any way to put a dab of superglue or JB Weld on the short end of a very small allen wrench and bonding it to the key remnant? Once bonded hold down the key release, gently wiggle the steering wheel and pull on the allen wrench? (You would certainly compound the problem if any adhesive bonded the key to the cylinder mechanism.)
Option 2...call a locksmith and ask him if there was a good time for you to stop by his shop to have him do his magic...ask in advance what something like that would cost...definitely don't have him come to your location and incur a service call fee. Good luck.
Old Jan 31, 2008 | 05:32 AM
tim3393's Avatar
I think once I get the cylinder out I should ba able to get it. There isn't any piece sticking out. Our maintenance guy at work has a key extractor that I am going to try.
Old Jan 31, 2008 | 05:39 AM
isaac338's Avatar
get a tube of quiksteel, rub some grease on the cylinder around the key (don't get any on the key!), and squish the quiksteel on there. stick a washer or something in it for a handy pulling handle
the grease will prevent the quiksteel from bonding to the cylinder, but it'll bond to the key. it'll be hard enough to pull out in about twenty minutes.
Old Jan 31, 2008 | 07:10 AM
gametom's Avatar
the PO broke a key off in the ignition and in the tailgate
i noticed that there is a weak spot in my key so i have to get a new one every year or so to prevent this from happening in my door
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
JamesDINAN
Sep 22, 2015 05:37 AM
JHalcyonM
Sep 14, 2015 01:10 AM
