URGENT! Help Replacing CV axle (95 4Runner)
So I'm stumped as to how to remove the CV axle. I looked at the 3rd gen CV axle replacement, but it is different than the 2nd gen. I need to drive this car ASAP because it is my DD. TIA
Phil
Phil
This should get you started
http://personal.utulsa.edu/~nathan-b...onandaxle.html
comes from here
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
comes from here
The only things that really hold it in are the 8 or so bolts on the flange and the C-clip inside the hub. Some find it easier to unbolt the upper ball joint to make the job easier, but then you're probably going to need an alignment.
voiddweller
19
May 2, 2016 09:10 PM
