General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
xenonlink.com anyone heard of or used them??
Old Dec 24, 2007 | 08:42 PM
ETRNL's Avatar
http://www.xenonlink.com/product_inf...roducts_id=114
i am desperatly awiting the next CNlight GB but i want my light by the 15th of Jan. so i am researching other options and came abotu this site. i googled them and found a couple ot simalar threads and it seems reliable. i am just looking for any yota members that heard of them if not even seen their products.. THNX in advance, ETRNL
Old Dec 25, 2007 | 08:41 AM
shaeff's Avatar
meh, i don't like that kit. that uses halogen hi beams. it's not good to be switching back and forth from hi's to lo's with HID/halogen setups. it drastically reduces the life of the HID, as it needs to properly cool down before you re-ignite it.
the kit i got is bixenon. (HID hi and lo beams) i also got a kit for my fogs. you can see them here: https://www.yotatech.com/50703483-post27.html
i had to modify the fog light shields in order to fit the longer bulb in, and i used hella 200mm glass e-code housings for my headlights. the pattern is decent, and the light output is amazing. mine are 6000k, both headlights and fogs.
Old Dec 25, 2007 | 03:45 PM
ETRNL's Avatar
hmmm, well my wife just ordered them for me.. hopefully they dont suck, anything over stock has to be better. i wonder if i can wire it up so instead of switching off the hid to burn the halogen high it uses both lights instead??
Old Dec 25, 2007 | 03:50 PM
yotasavg's Avatar
hey your's look great! if you don't mind me asking: how much did they cost for the headlights?
also, would they work with the runner style headlights?
Old Dec 25, 2007 | 04:12 PM
ETRNL's Avatar
well i just found this site. i might have to buy these and convert the others into some fog lights..
http://www.xenondepot.com/category.php?category_id=4
these would be much better right??
Old Dec 25, 2007 | 07:02 PM
Midget96's Avatar
I have a similar kit (same bulbs, different name on the ballast). The HID lows stay lit when the highs are used.
Old Dec 25, 2007 | 07:27 PM
Fo_SheeZy's Avatar
I just ordered an 8K bi-xenon kit from oznium.com I'll post pics within a week or two and let you all know what I think.
Old Dec 26, 2007 | 07:42 PM
shaeff's Avatar
are the 4runner headlights the same as the pickup's? stock are sealed beam H4 style lenses on my pickup. i'm not familiar with 4runners. however, you can get the kit that i got with any bulb base to fit the wiring in your vehicle. as for a cutoff, i can't say, as i haven't seen the same kit as mine in 4runner headlight housings (unless they're the same as the pickup's)
depends on what kind of bulb your fogs take. mine are h3, so i got h3 based bulbs, and modified the shield to accept the longer HID bulbs. your application may vary.
ah, i'd still prefer to have the HID high's. they're incredible. however, it's good to know that the HID's in yours don't constantly get turned on and off. that will prolong bulb life. my HID highs light up so much, it's really pretty ridiculous.
for what it's worth, the kit i got was made by a chinese company called Easysee. sounds cheesy, but they're pretty good quality.
for those of you thinking of ANY ebay special diamond cut headlights, just don't. all you'll do is blind other drivers with your terrible light pattern. safety is key here, as the HID's will literally disorient people if you have them adjusted improperly, or use crappy lenses that scatter the light rather than pinpoint it to where you want with a sharp cutoff.
Old Dec 26, 2007 | 07:46 PM
yotasavg's Avatar
hey thanks for getting back shaef. no the headlight is not the same but the i'm pretty sure it's still an H4 if i remember correctly. but how much did the kit run you?
Old Dec 26, 2007 | 08:14 PM
shaeff's Avatar
no problem.
i got it through a group buy on supramania.com (i'm a supra owner, and the mk3's take the same h4 style sealed beams as my pickup)
i think i paid about $300 total, shipped to my door. maybe a bit less.
Old Dec 26, 2007 | 08:19 PM
ozziesironmanoffroad's Avatar
i think ill stick with my halogens. .
Old Dec 26, 2007 | 08:34 PM
shaeff's Avatar
small price to pay for exemplary lighting, in my opinion. i'll most likely never go back to halogens for headlights.
ashamsuddin
17
Jul 22, 2024 03:59 AM
zytra
Jan 24, 2019 03:16 PM
Obmi
Oct 4, 2015 11:30 AM
creecher10
Sep 30, 2015 03:27 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
