anyone know what this connector goes to?
I found this just below the driver headlight, all the headlights, foglights, turn signals are hooked up and work properly.....what is this one?
unless theres one outside of the radiator, it doesnt have one. This truck is completely stock not a single aftermarket item to be found on the vehicle except for some floor mats
I just bought it saturday
I actually have one too. I have no idea what it is for . It is not a fog light connector because I have put in fog lights from the factory and they are each one pink wire with a white tracer and one black ground. These are on both sides which are meant for fog lights, but this connector is on the drivers side above the foglight connector. Does the tranny cooler have a temp sender that this connects to? I have a 3.4 with the r151 5-speed year 2000 SR5.
CURSES you beat me to it!
It is indeed an ambient temp sensor. Typically the SR5 4runners didn't have it, the LTD did but they were all wired for it. You may just be able to put a sensor on there (bolted to the core support) and have it work.
some drunk guy
Aug 3, 2021 06:09 PM
mct75
Aug 22, 2016 01:24 PM
