ran fine this morning need help now!!!??
93 4runner 3.0 4x4 ran great this morning like a top went to start it 20 mins ago now i have a rough idle and it wont stay started the plugs wires cap and rotor have 2500 miles on them timing was checked 10 btdc like it should be vac lines seem fine what happend in a couple hours ??? anyone ?? i need help now have to get fix before tomorrow
have you checked for water in the oil, or oil in the water. take a good look at your head gasket. if i am not mistaken, and i hope i am, white smoke is water in the combustion chamber, if it is doing it after everything has warmed up, then it is not condensation . 3.0 have a bad rap for their head gasket
no oil in the water or water in the oil that was my FIRST look lol im thinking tps right now while in gear its sugring kinda hunting for rpms either that or i jumped a tooth on the timing ill be back in about 20 mins
so... ive just got done testing the TPS and its working fine! so... my runner is still looking for a happy place at idle ( its idling very low 250 and surging up to 1200) its also blowing dark exhaust fumes ( not white which would lead one to the HG) so its running rich and surging im thinnking TIMING anythoughts beyond that ? that being said how about some opions on DIY timing belt ive never done one on a yota looks easy have the fsm im looking now for tricks to it so FIRE AWAY
i had the same problem, but all i had to do was buy part of the air hose that connects to the throttle body, it wasnt sealed good enough "meaning the previous owner had it ELECTRICAL-TAPED" to try and seal it. :p
if theres a leak then theres no vacuum seal, which powers like everything and youre fuel/air ratio, im no expert but i can maybe guess its just a not clean explosion, i had to constantly keep the idle up at stop lights just to not kill it.
