ran fine this morning need help now!!!??
Old Dec 5, 2007 | 12:39 PM
88Yota4runner's Avatar
well for me it was the small rubber piece that connects right onto the throttle body, i went to toyota and it was 77 bucks.
Old Dec 5, 2007 | 12:42 PM
swaycleveland's Avatar
ahhhh
Old Dec 5, 2007 | 02:02 PM
MudHippy's Avatar
Originally Posted by 88Yota4runner
...part of the air hose that connects to the throttle body, it wasnt sealed good enough "meaning the previous owner had it ELECTRICAL-TAPED" to try and seal it. :p
Like mine you mean?
I would be checking my EGR valve too. Would act just like any other vac leak if it were stuck open. Might cause the smoking too.
Doesn't sound like timing to me.
Old Dec 5, 2007 | 02:12 PM
billmaness's Avatar
This doesn't sound like timing. It is a fuel/air ratio problem. It could be a bad sensor, elec connection, vac leak, etc. My first guess though would be an air leak in the big hose between the air filter and the TBI as earlier suggested.
Old Dec 5, 2007 | 02:41 PM
  #25
hmm i did jsut replace the belts ps alt and such they are hooked up i did check the egr it works stalled the motor tps working fine ive been looking for vac leaks all day hoping that was it thats why im thinking timing
Old Dec 5, 2007 | 02:42 PM
  #26
i mean seriously i parked in the garage 2 hours later the trucks running like crap this just after getting the best fuel milage ever 310 on one tank!
Old Dec 5, 2007 | 02:48 PM
  #27
TORTIS's Avatar
that usally means you are about to be screwed.
Old Dec 5, 2007 | 02:52 PM
  #28
yep i figured that something had to come and bite me
Old Dec 5, 2007 | 03:03 PM
  #29
TORTIS's Avatar
does the flap in the air box move freely. AFM i think it is called.
Old Dec 5, 2007 | 03:05 PM
  #30
infiltrator's Avatar
DAMN 310 ON A TANK!!! jeez!
I GET 210 ON ALL FREEWAY MILES!!!
whats your secret? how big are your tires?
Old Dec 5, 2007 | 03:07 PM
  #31
stock 31s did the air box mod and cleaned egr greased everything syn oil everywhere! thats the secret
Old Dec 5, 2007 | 03:45 PM
  #32
ozziesironmanoffroad's Avatar
do a pressure check in all the cylinders. it kind of sounds like a HG problem, but no white smoke? thats odd...
Old Dec 5, 2007 | 03:53 PM
  #33
yep only stumbles and hunts at idle hit the gas and she goes just fine nope no white smoke no leak no oil water mix i can see never over heated horrible idle like its so far out of timing but im not sure if i jumped a cogg or i have a
vac leak
Old Dec 5, 2007 | 05:14 PM
  #34
TORTIS's Avatar
just remember, mine did not have any white smoke and the HD gasket was leaking to the outside of the block. keep an eye on the water level.
Doug4320
Mar 24, 2018 10:11 PM
redneck17
Jul 17, 2015 07:44 PM
kyletbert
Jul 17, 2015 11:39 AM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
