Hendrix Motorsports Carrier Bearing Support
Old Dec 4, 2007 | 01:26 PM
TORTIS's Avatar
anybody running this carrier bearing support. i don't want to keep changing it out on my 89 truck. a 1 piece drive shaft is $200, but would rather have the ground clearance of a 2 piece. i know you have to turn down the yolk a little to get a solid fit. http://pirate4x4.com/forum/attachmen...1&d=1157514160
Old Dec 4, 2007 | 01:32 PM
Aaronn's Avatar
I run one..it is not a bolt-up application..you'll have to fab. a mount for it..you may get a little vibration from it as it's mounted with urithane(sp?) bushings....nice piece though..
Old Dec 4, 2007 | 02:01 PM
TORTIS's Avatar
fab is no problem. how long have you been running it? where did you get the bearing? did you have to turn the yolk down?
Old Dec 4, 2007 | 03:08 PM
Aaronn's Avatar
I've been running it for about 3 years(in a buggy) You don't have to turn down anything...Take your existing carrier bearing and tear it apart..remove everything until you get just a bare sealed bearing...That bearing should be a light press fit into the carrier..install snap ring..slide shaft through the bearing...bolt on flange..attatch to mount you have made...peal out
If you need more info let me know..I have one here I can strip dow to get ready for instal
Attached Thumbnails Hendrix Motorsports Carrier Bearing Support-dsc01628-2-.jpg   Hendrix Motorsports Carrier Bearing Support-dsc01627-2-.jpg
Old Dec 4, 2007 | 04:32 PM
TORTIS's Avatar
ok. thanks for the offer. i will order one tomorrow and if i run into problem i will PM ya. thanks again.
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
scott90
Oct 4, 2015 09:21 AM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
