General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
electric fan wiring help?
Old Nov 25, 2007 | 06:54 PM
beaufredrides's Avatar
i just bought a flex-a-lite electric fan for my 88 4runner with the 3vze and i need a little help with the wiring. the instructions say:
"Connect the "+" terminal of the control box to a 12v positive (+) power source (i.e. fuse box), using the thin red wire and fuse taps (if necessary) provided in the kit."
i have absolutely no idea how to do this, as i am electrically challenged. any help or further explanation would be greatly appreciated. thanks!
Old Nov 25, 2007 | 07:05 PM
4Crawler's Avatar
Just connect into a wire with 12 volts on it, if you want the fan to run anytime, use a wire that is always hot (I added my own wire out of the fuse box - w/ separate fuse/circuit breaker) for the fan, otherwise use a wire that switches on and off with the ignition:
http://www.4crawler.com/4x4/CheapTri...tml#FanControl
Old Nov 25, 2007 | 07:11 PM
do you know where i can find one of these ignition controlled wires?
Old Nov 25, 2007 | 07:16 PM
4Crawler's Avatar
Lots of them under the hood. Bes tip is to invest in a volt meter or a simple test light and start poking around. You can get a volt meter for $3:
- http://www.harborfreight.com/cpi/cta...emnumber=90899
Or get ahold of a Factory Service Manual wiring diagram for your year truck and look at that, it'll give you the location and color code of those type of wires.
rowdy235's Avatar
If it were me I would grab a wiring diagram and locate the wire which comes out off the "ON" terminal on the ign switch, behind the steering column.
Old Nov 25, 2007 | 07:37 PM
would i just be able to run it out of the fuse box, on say the ignition fuse?
Old Nov 25, 2007 | 08:00 PM
would a fuse tap actually work?
Old Nov 25, 2007 | 08:55 PM
rowdy235's Avatar
if you could find a fuse that only has power when the ign is on.
Old Nov 25, 2007 | 09:42 PM
4Crawler's Avatar
Or read this article in the tech section:
https://www.yotatech.com/forums/f127.../#post50390749
Old Dec 1, 2007 | 06:16 PM
itjobhunter's Avatar
Just posting this so everyone knows:
The AC wire you need for the controller is connected right to the compressor; but it is easily (and cleanly) accessible in the wire bundle at the firewall on the passenger side. I searched all over for this info, and finally had to track it down.
I hope it can save someone else a lot of time!
Just check the wire color at the compressor and opened the huge bundle by the firewall and find the same color wire. Do a continuity test before tapping in though! The colors on the wires can be VERY similar.
My pics were too big for this forum, or I would have them up too.
Old Dec 1, 2007 | 07:04 PM
frodin1's Avatar
I don't want to make things more difficult for you in any way. But I've seen more than a couple threads now about these fans pulling quite a bit of amps and melting the wiring. I would make sure you use heavier wiring and maybe even go as far as soldering the joints. I'm not sure if the fans I ws reading about were dual fans or not but I just wanted to throw that out there and prevent a possible car B-Q.
Old Dec 1, 2007 | 07:28 PM
seafarinman's Avatar
I recommend getting a fixed temperature thermo fan controller (such as the ones that you see at the auto parts stores-I am running a 180* one) and a constant duty solenoid (I have a 85A one from West Marine $39). Without the constant duty solenoid I was melting the 30A relays on the fan controller. I used the fan controller to turn on the solenoid which easily handles the startup current draw. I am running a Taurus fan so it draws a lot of current on startup.
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
jackiebrownia
Jul 20, 2015 09:02 AM
1996Taco
Jul 20, 2015 12:02 AM
zd92655
Jul 5, 2015 04:25 PM
