electric fan wiring help?
i just bought a flex-a-lite electric fan for my 88 4runner with the 3vze and i need a little help with the wiring. the instructions say:
"Connect the "+" terminal of the control box to a 12v positive (+) power source (i.e. fuse box), using the thin red wire and fuse taps (if necessary) provided in the kit."
i have absolutely no idea how to do this, as i am electrically challenged. any help or further explanation would be greatly appreciated. thanks!
Just connect into a wire with 12 volts on it, if you want the fan to run anytime, use a wire that is always hot (I added my own wire out of the fuse box - w/ separate fuse/circuit breaker) for the fan, otherwise use a wire that switches on and off with the ignition:
http://www.4crawler.com/4x4/CheapTri...tml#FanControl
- http://www.harborfreight.com/cpi/cta...emnumber=90899
Or get ahold of a Factory Service Manual wiring diagram for your year truck and look at that, it'll give you the location and color code of those type of wires.
Or read this article in the tech section:
https://www.yotatech.com/forums/f127.../#post50390749
Just posting this so everyone knows:
The AC wire you need for the controller is connected right to the compressor; but it is easily (and cleanly) accessible in the wire bundle at the firewall on the passenger side. I searched all over for this info, and finally had to track it down.
I hope it can save someone else a lot of time!
Just check the wire color at the compressor and opened the huge bundle by the firewall and find the same color wire. Do a continuity test before tapping in though! The colors on the wires can be VERY similar.
My pics were too big for this forum, or I would have them up too.
I don't want to make things more difficult for you in any way. But I've seen more than a couple threads now about these fans pulling quite a bit of amps and melting the wiring. I would make sure you use heavier wiring and maybe even go as far as soldering the joints. I'm not sure if the fans I ws reading about were dual fans or not but I just wanted to throw that out there and prevent a possible car B-Q.
I recommend getting a fixed temperature thermo fan controller (such as the ones that you see at the auto parts stores-I am running a 180* one) and a constant duty solenoid (I have a 85A one from West Marine $39). Without the constant duty solenoid I was melting the 30A relays on the fan controller. I used the fan controller to turn on the solenoid which easily handles the startup current draw. I am running a Taurus fan so it draws a lot of current on startup.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
